Brake warping...
Old Apr 15, 2002 | 06:22 AM
Ohlias's Avatar
Default Brake warping...
I've had my car for a year now and the other day on the highway I had to brake hard and the steering shook noticibly. I was going about 140km/h (yea, I was speeding, it happens). I've never taken a car into a dealership before for work, but I was wondering; Would discs be covered under warranty? I know "wear and tear" items are not. Like Pads and clutch, but what about Discs?
TIA
Ohlias
Old Apr 15, 2002 | 06:34 AM
bps2799's Avatar
Default Re: Brake warping... (Ohlias)
You're SOL, unless Canada makes "wear and tear" items part of the warranty coverage.
Shell out the $$$ for new rotors, but not at the dealership.
Old Apr 15, 2002 | 06:36 AM
Scary1109's Avatar
warping your disks will happen, i have no idea if they are covered, but if they aren't, it's not a hard job to do it your self. if you do replace them yourself, just get a set of brembo blanks with good pads.
-Scary
Old Apr 15, 2002 | 08:27 AM
Ohlias's Avatar
Default Re: Brake warping... (Scary1109)
Can the rotors be machined? If they have to be replaced, what is the best/cheap solution, while keeping the stock setup (pads and calipers). How much am I looking at spending? I want something that is at least as good as stock, and I figure, if I'm gonna change, might as well be better...
TIA
Ohlias
Old Apr 15, 2002 | 08:37 AM
Rtzx9r's Avatar
GDD 1%
They covered mine. Hell I got new Rims too because of the corrosion!!
Old Apr 15, 2002 | 08:45 AM
reefer_bob's Avatar
You can have your rotors turned... costs like 10 - 15 USD at a auto parts store... New pads, DIY... you'll be fixed up for around 100 USD...
Old Apr 15, 2002 | 08:53 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Brake warping... (reefer_bob)
I just bought 2 new rotors and a set of pads from AutoZone this weekend, about $70 total. I installed the pads but I can't change the rotors until I get access to a drill and drill out the rotor screws.
Old Apr 15, 2002 | 11:14 AM
Ohlias's Avatar
Default Re: Brake warping... (PatrickGSR94)
what kind of rotors?
My friend is a mechanic and he would probably help me do it. I guess I would just have to jack the car up and take off the wheels...any special tools needed?
TIA
Ohlias
Old Apr 15, 2002 | 11:24 AM
GSRaCeRbOI's Avatar
you could try taking it to the dealer to see if they'll cover it.. but I dont think they will.. its worth a try though.. for replacements.. I got Brembo blanks/solid rotors and Hawk HPS pads (like $65).. their only about $30/ea.. I got mine from http://www.collettimotorsports.com its $28/ea plu $10 shipping.. another place is http://www.performancemotorcars.com its like $32/ea but then shipping is free for orders over $50.. so it comes out less.. but then again you don't live in the US right?.. so I dont know how that would work...
as for tools its pretty easy.. jack, jack stands, socket set/ratchet, impact screwdriver to take out the brake rotor screws, C-clamp or brake spreader if your changing the pads too, bungee cord or something to hang the caliper on so it doesnt hang on/stretch the brake line, high temp brake grease for the caliper bolts, etc.., brake quiet/molykote for the back of the pads, torque wrench to torque the torque plate/caliper and pad mount and caliper back on.... its pretty easy.. you shoud be done in 30-45 mins...
Old Apr 15, 2002 | 12:55 PM
reefer_bob's Avatar
Default Re: Brake warping... (GSRaCeRbOI)
Nope, not dificult at all, however... If you're not use to doing brakes, it's really best to have someone there who has done it before. Brakes are not a good thing to learn on. They are rather important.
One very important note, after you do the brake job, pump up the brakes before you try to drive. When you back out of the drive way, make sure you can stop. I've seen a guy just take off right after he did brakes. He ramped up over the curb across the street... Pump them up!!!
Old Apr 15, 2002 | 02:54 PM
Ohlias's Avatar
GSRaCeRbOI and reefer_bob thanks for your info. I really appriciate it. I'm pretty sure my mechanic friend has all of the tools and the expereice (he just started though). I'll probably have to buy some of the grease you mentioned...
Thanks guys,
Ohlias
Old Apr 15, 2002 | 05:43 PM
GSRaCeRbOI's Avatar
oh yeah almost forgot to give you this link.. everything should come together now that you have text AND pix... good luck...
http://www.bseries.net/html/garage/brakes.php
Old Apr 15, 2002 | 06:52 PM
Padronis's Avatar
One more thing, If you have access to an impact driver, use that to take out the rotor screws. A regular phillips will much more likely round out the head.
Old Apr 16, 2002 | 10:40 AM
Ohlias's Avatar
thanks again guys!
ShinotakuX
28
May 17, 2018 12:29 PM
Genesis777
Sep 2, 2017 10:31 AM
06siracer
Honda Civic (2006 - 2015)
10
Aug 31, 2007 11:16 PM
cltitus
Apr 26, 2007 06:40 PM
ArtificialSynapse
Mar 20, 2007 08:04 AM
