Drivers side door lock problem....
Old Jun 4, 2006 | 06:10 AM
BHNTech's Avatar
Default Drivers side door lock problem....
Hey guys,
When i put the key in my drivers side door and turn the key arn't all the doors sopposed to lock? My rear door won't lock my driver side does of course and so do the passengers, but the rear driver doesn't, also are the doors sopposed to unlock as well in the same manor? don't think my passenger sides do.. where would i look for this problem? i wager maybe there is a wire loose or something. as i can hear the lock trying to work in the rear drivers side, but it won't do anything.
Will G
Sorry all 94 Accord 4dr LX
Modified by BHNTech at 7:46 AM 6/4/2006
Old Jun 4, 2006 | 07:43 AM
someone else's Avatar
It Wasn't Me!
Default Re: Drivers side door lock problem.... (BHNTech)
If it makes noise and moves a little but won't lock/unlock you most likely have a bad door lock actuator. Not a very hard repair.
Old Jun 4, 2006 | 08:43 AM
BHNTech's Avatar
Default Re: Drivers side door lock problem.... (hondasean)
think it makes noise but moves non, i will look in the junk yard for an actuator to repair this. thanks for the assistance.
Will G.
Old Jun 4, 2006 | 01:41 PM
02 accord's Avatar
For unlocking all the doors with the key, you have to turn it (unlock) and hold it there for a second or two. Then all the doors should unlock.
Red-Rag-B18
Acura TSX
Apr 30, 2013 09:12 AM
The GreenD16
Apr 2, 2013 02:45 PM
blacktibby07
Feb 5, 2011 06:37 AM
MasterCrx
Oct 7, 2005 01:06 PM
nyk52687
Aug 3, 2004 11:57 AM
