Takata Harness with recaro SRD's
Hey guys I currently have recaro srds and am looking at purchasing the takata harnesses. I have a couple of questions though
1. Should I get the long or short? I dont have a roll cage or anything yet but i may get one down the road. Whats the difference between them (obviously 1 is longer, but what is the purpose of the short and the long)?
2. I have seen 4 point and 5 point. hich is better? Which should i get?
3. Can they be installed with the interior in? If not what would have to be removed and/or cut?
Thanks
Thanks
there is nothing wrong wit Takatas..you OEM seat belts are also made by Takata. True they are overpriced but if you have the money to spend then go for it.
5 point harnesses are for race seats They usually have a 3rd hole on the bottom portion of the seat to slip the bottom of the harness though.
If you plan on getting a roll cage or bar go long. even if you don't plan on getting a Roll bar still go long but I would recommend do not use the harnesses unless you have some kind of other safety measures (i.e. roll Bar)
Yes they can be installed with the interior in but you have the put the eye bolts in the place of your seat belt in the back under the bottom seat cushion
Chris F
14
Oct 16, 2004 07:50 AM
IGGY
Aug 17, 2002 04:02 PM
