Spark Plugs?
Old Jun 4, 2006 | 12:15 AM
EM1FORLIFE.'s Avatar
Default Spark Plugs?
Modified by EM1FORLIFE. at 8:29 AM 10/4/2006
Old Jun 4, 2006 | 12:36 AM
Leo C's Avatar
Night Owl
Default Re: Spark Plugs? (EBP EM1)
those are good, similiar to the NGK iridium pulgs, these do have a colder heat range than normal plugs though
Old Jun 4, 2006 | 12:40 AM
Proglow3's Avatar
Default Re: Spark Plugs? (shutupnskate)
Colder is going to be a good thing if you have a decent intake and exhaust!
Old Jun 4, 2006 | 02:04 AM
jdm_ekcivic's Avatar
They should be good, they are OEM plugs for 99-00 SIs.
Old Jun 4, 2006 | 05:21 PM
Old Jun 4, 2006 | 05:30 PM
ProjeKt's Avatar
In Basic Training
I doubt it does maybe like .00000002131231241241 HP more
Old Jun 4, 2006 | 06:25 PM
Toyo TI-S Spec's Avatar
Default Re: Spark Plugs? (ProjeKt)
If you do a little research, your cheap copper core spark plugs will you the most power simply because copper is the superior conductor when compared to iridium and platinum. The only thing wrong with copper is it won't last as long as the other two so you'll have to change them more often but simply switching to those expensive plugs that claim all sorts of stuff isn't worth it because you won't feel any difference. There are plugs that have more than 1 tip such as the bosch +2 and +4 and the iridum has a design that allows for a better spark but really, the differences isn't big enough to be significant. .00000032483 more hp like Projeckt said.
Smokey5176
May 8, 2007 05:01 PM
hatchback
Jun 28, 2003 10:47 PM
