Oil Pressure gauge
Go to stealthmode, tuner-toys or fast-turbo and get a stainless line with a splitter fitting on the end. You need to run the line away from the block and mount the splitter somewhere on the firewall and then hook the stock oil fitting and gauge fitting onto that.
Tees directly off of the block are well known to crack, break and cause really bad messy problems.
