Swapped Motor with CA Emissions in San Diego
Old Jun 3, 2006 | 06:37 PM
94RedEGCoupe's Avatar
Default Swapped Motor with CA Emissions in San Diego
Hey, can anyone help with a hook up on where to get my car smogged in San Diego? I just moved here and I hear if you have a swap you won't pass. Thanks fo rthe help
Old Jun 3, 2006 | 06:48 PM
2fast4u831's Avatar
I'm really 2slow
Default Re: Swapped Motor with CA Emissions in San Diego (94RedEGCoupe)
what engine? what car? what ecu? info. please
Old Jun 3, 2006 | 08:23 PM
Default Re: Swapped Motor with CA Emissions in San Diego (2FAST4U831)
its a 94 civic coupe with a jdm b18c and jdm gsr ecu
Old Jun 4, 2006 | 02:11 PM
Essenar83's Avatar
Firstly, you need a USDM GSR intake manifold, carb legal exhaust manifold, make sure the swap is OBD1 and under an OBD1 ECU. Every bolt on has to be carp legal. If your ECU is chipped, convert it back to stock settings. any type of richness in the fuel/bump mapping will cause you to fail the smog check. REF's do smog checks when they're doing a swap inspection.
With all that OK, you'll be alright and you'll pass ref/smog inspections. In short, no race-only parts and no ebay-cheap ****. uSDM intake/exhaust manifold on top of that and you're good.
Old Jun 4, 2006 | 06:57 PM
Default Re: (Essenar83)
I actually passed this morning. Maybe having the swap done by a guy that works at honda helped? I guess I was worried for nothing...Thanks for all the advice
djviet2000
Mar 3, 2008 10:47 PM
Lethalb18c1
Dec 17, 2006 08:51 AM
kDA
Aug 9, 2006 10:16 AM
DynamicDevelopment
Dec 22, 2005 05:17 AM
Cashflo
Jan 14, 2003 12:33 PM
