1988 Prelude ----ECU CODE HELP
Old Jun 3, 2006 | 04:19 PM
RE- v8killa121's Avatar
Default 1988 Prelude ----ECU CODE HELP
where do i find the wires i need to jump so the ecu can show the codes it has???
i searched and couldn't find it for an 88'
need this fast please!!
thanks
Old Jun 3, 2006 | 04:42 PM
prelude1897's Avatar
Default Re: 1988 Prelude ----ECU CODE HELP (RE- v8killa121)
could just go to Auto Zone and have them do it for FREE
Old Jun 3, 2006 | 04:59 PM
Default Re: 1988 Prelude ----ECU CODE HELP (prelude1897)
wha?
the check engine light is on on my uncles car, and i wanna check to see what codes it's throwin out..
but i can't figure out where the wires are that i need to clip together...
i know that on my old EK it was on the pass. side by the ecu, and on my EF it in the engine bay (driver side) but i can't find it on this prelude...
do these old preludes even have this??
Old Jun 3, 2006 | 05:21 PM
GlenWatkins's Avatar
On 3rd gen Preludes you do NOT need to jumper anything to read the codes. Pull down the carpet on the Passenger side (right side) and you will see the clear plastic window.
Turn the ignition on without starting the car. The red led will blink out the trouble code/s.
Old Jun 3, 2006 | 07:36 PM
Default Re: 1988 Prelude ----ECU CODE HELP (GlenWatkins)
really?
let me check it out
Thank alot!!
Old Jun 4, 2006 | 05:20 AM
Jagan'92's Avatar
ya, I like that little blinking window in the ecu.
Old Jun 6, 2006 | 07:45 AM
nx h22's Avatar
what about on an obd1 lude were do you find the codes in that car
Old Apr 18, 2022 | 08:27 AM
djgreg's Avatar
I'm hoping someone can tell me where I'm looking wrong. I have a third generation 88 Prelude 2.0 SI and my check engine light comes on randomly sometimes almost as soon as I start the vehicle up I really would like to get to the bottom to find out what is causing it to come on as I've already spent a ridiculous amount of money swapping out parts that thinking it could fix it and it doesn't. When I pull back my carpet on the passenger side I see the piece of metal that covers the transmission computer and the ECU but there is no plastic window or an LED light is flashing I've tried both would just ignore Shane key on and with the car running with the CEL lifht on... I have attached pictures of all corners of this area is someone can point to me where I'm looking wrong and maybe find this so-called LED lights it would certainly be appreciative. Even my local Honda dealer can no longer check this because they don't have the equipment to do so. One of my best friends works in the service department at my local Honda dealership and he himself tried to find a way for me and was not able to. If anyone with ideas of how I can figure out why the light is coming on, please email me at djgreg1972@gmail.com
Old May 22, 2022 | 06:54 AM
djgreg's Avatar
why am I not able to locate this so-called Clear Window on my passenger floorboard? I have an 88 2.0 SI
SIkilla
Mar 22, 2009 09:46 AM
1988c-rex
Aug 13, 2005 11:11 PM
ATS*JSJ EK9
Jul 26, 2003 06:54 AM
turbotypeR@SPEC
Dec 28, 2001 11:48 PM
