Part numbers for LS 5th gear swap??
Old Jun 3, 2006 | 03:23 PM
brokeHonda's Avatar
Default Part numbers for LS 5th gear swap??
Yep- I searched
Just to confirm the #'s
Mainshaft 5th: 23451-PS1-A02
Countershaft 5th: 23461-P80-000
Eh??
Old Jun 3, 2006 | 10:44 PM
brokeHonda's Avatar
Default Re: Part numbers for LS 5th gear swap?? (brokeHonda)
Nevermind!
98+ ITR tranny has a 0.787 5th which is comparable to the GSR 5th! 95-97 ITR had the 0.878 No need to spend the extra cash just yet.
Old Aug 17, 2006 | 09:56 AM
PickleTeg's Avatar
Subscribed for the part numbers...thanks man
PickleTeg's Avatar
Default Re: Part numbers for LS 5th gear swap?? (PickleTeg)
Got it now
Old Dec 15, 2006 | 08:56 PM
pizzaboysos's Avatar
are these the correct part #'s for the ls 5th gear
Old Dec 16, 2006 | 02:18 PM
non-VTEC's Avatar
Default Re: Part numbers for LS 5th gear swap?? (pizzaboysos)
who cares what the actual part numbers are.....just go into the dealer and specifically ask for any 94+ integra LS main and counter shaft gears.....
if your parts guy has half a brain he will give you the correct parts.
Old Dec 16, 2006 | 02:23 PM
Default Re: Part numbers for LS 5th gear swap?? (non-VTEC)
ya well thats the prob the parts guys in town are stupid i went in and asked 4 honda bond and they looked @ me like i was on crack
Old Dec 23, 2006 | 10:28 PM
lek9l's Avatar
Does anyone know if an LS 5th Gear can work in a USDM 94-01 GSR Tranny. If so, which model of LS will work?
Old Dec 24, 2006 | 06:26 AM
IN VTEC's Avatar
For the .714 gear ratio, use the '94 to '01 LS Y80 gears.
Countershaft: 23461-P80-000
Mainshaft: 23581-P80-000
For the .742 gear ratio, use the '90 to '93 LS S1/YS1 gears.
Countershaft: 23461-PS1-A01
Mainshaft: 23581-PS1-A00
You can safely use the .742 gears in YS1 GS-R transmissions. I can't exactly remember if I ever tested my S80 GS-R gears in the YS1 transmission I built for somebody, but I think I did, and they slid on there just fine. I'll have to see about that the next time I happen to have a set of both apart.
Old Dec 26, 2006 | 06:48 PM
Default Re: Part numbers for LS 5th gear swap?? (IN VTEC)
so your telling me i ordered the wrong mainshaft gear and you can confirm this i would just like 2 know if i need 2 order the # you posted or not
Thanks
Matt
Charlie Moua
Sep 28, 2011 12:56 PM
dinthanonh
Transmission & Drivetrain
Apr 19, 2010 05:17 PM
092eg6
Nov 18, 2009 11:05 AM
BIG T
Apr 12, 2008 05:45 AM
JDMKid71
12
Oct 25, 2006 09:35 AM
