question about GSR brakes on a eg hatch
Old Jun 3, 2006 | 02:59 PM
chunkybs's Avatar
Default question about GSR brakes on a eg hatch
i need to replace my rotors and pads soon and i was thinking. i know one of my buddies has GSR brakes on his EG sedan. so my question is, when i order new rotors should i get normal '94 Si (already has 4 wheel disc factory) or should i get GRS rotors? these are my concerns: will they fit into Si steelies? will i still be able to use the Si calipers?
Old Jun 3, 2006 | 03:02 PM
sohcvtec1995's Avatar
Default Re: question about GSR brakes on a eg hatch (chunkybs)
si ones. the gsr ones are different at least the caliper design is.
Old Jun 3, 2006 | 03:03 PM
sol2hatch's Avatar
your buddy probably did a brake swap. Those rotors are bigger, so you wont be able to use them
Old Jun 3, 2006 | 03:14 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chunkybs &raquo;</TD></TR><TR><TD CLASS="quote">i need to replace my rotors and pads soon and i was thinking. i know one of my buddies has GSR brakes on his EG sedan. so my question is, when i order new rotors should i get normal '94 Si (already has 4 wheel disc factory) or should i get GRS rotors? these are my concerns: will they fit into Si steelies? will i still be able to use the Si calipers?</TD></TR></TABLE>
What car and brakes do you currently have? Your signature says one thing, and your post says another. There were also two different brake configurations available for the '94 EH3 Si (Si and Si-ABS).
Also, some '92-95 Civic sedans (the LX-ABS and the EX) were equipped with the same brakes as "GSR" Integras (which are the exact same brakes found on all other '94-01 Integras except the Type-R).
Old Jun 3, 2006 | 03:37 PM
chunkybs's Avatar
mine is a '94 Si with ABS
Old Jun 3, 2006 | 03:45 PM
EL Vap133's Avatar
Default Re: (chunkybs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chunkybs &raquo;</TD></TR><TR><TD CLASS="quote">mine is a '94 Si with ABS</TD></TR></TABLE>
Then does that mean you have the stock Si suspension? If so, why would you want to order anything different than what you have?
Old Jun 3, 2006 | 04:10 PM
chunkybs's Avatar
Default Re: (EL Vap133)
no, i have tein flex dampers. so you think just picking up some OEM replacement rotors is my best bet then?
Old Jun 3, 2006 | 04:18 PM
Brembo blanks
Old Jun 3, 2006 | 04:21 PM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chunkybs &raquo;</TD></TR><TR><TD CLASS="quote">no, i have tein flex dampers. so you think just picking up some OEM replacement rotors is my best bet then?</TD></TR></TABLE>
What brakes do you have on your car????
Old Jun 3, 2006 | 04:23 PM
Targa250R's Avatar
be professional
Then you already have the exact same brakes as an Integra.
Old Jun 3, 2006 | 04:24 PM
EL Vap133's Avatar
Default Re: (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">
Then you already have the exact same brakes as an Integra.</TD></TR></TABLE>
You sure the 94 Si came with the bigger brakes?
Old Jun 3, 2006 | 04:33 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">You sure the 94 Si came with the bigger brakes?</TD></TR></TABLE>
The Si-ABS model had 10.3" front rotors with 17CL14VN calipers and the ubiquitous 9.5" rear disc setup. That's exactly what all '94-01 Integras (except ITR) were equipped with.
The Si without ABS had 9.5" front rotors and used the same calipers as found on CX/VX/DX/LX Civics.
Old Jun 3, 2006 | 04:50 PM
chunkybs's Avatar
well in that case, then i'll just pick up some OEM replacements and car it good.
my car currently has stock brakes, stock '94 Si with ABS brakes
doogi0122
May 17, 2007 09:39 AM
eg4life1202
Oct 26, 2006 08:50 AM
ne3ek
Dec 22, 2005 08:58 PM
spoonef
Northwest (Sales)
11
Oct 16, 2005 02:33 PM
AmauryR
Jun 19, 2002 06:38 AM
