to all 3" custom exhaust builders: quick question
Old Jun 3, 2006 | 01:50 PM
non-VTEC's Avatar
Default to all 3" custom exhaust builders: quick question
hey guys
I'm going to be building a custom 3" exhaust system for my integra very soon. i was wondering what type of bends i need in the rear section to go over the control arm/axel back. i'm buying pre-bent mandrel pipes.
would i take 2 90deg bends and cut them up and over......or do i use 2 45deg bends?
Old Jun 3, 2006 | 03:08 PM
turbotommy's Avatar
Default Re: to all 3" custom exhaust builders: quick question (non-VTEC)
buying one 90 deg section will be cheaper than buying two 45's. if you have the tooling to cut and sand where needed go for the 90's or possibly u-bends (180 deg).
two 90 deg sections will more than enough material for the axle back section. i personally like to venture between the gas tank and lower control arm..
Old Jun 3, 2006 | 06:35 PM
4genaccordfreak's Avatar
if it was possible for you to have access to a nice band-saw.. you can make your own PIE-CUT bends.. thats what we always did at the shop for Down-pipes, IC Piping and full exhausts.. PLUS: that way is alot more cost efficient since all straight piping is needed.. although the band-saw would have to have a turnable vise with hash marks for cutting angles.. we always cut 7* pie's for smooth bends and 15* pie's for tighter bends..
here's a pic of what i mean.. from a friends car:
RACEPAK
37
Mar 31, 2007 05:15 AM
pjr710
Dec 4, 2006 06:00 AM
RCautoworks
Welding / Fabrication
Oct 18, 2004 10:37 PM
JDM H22A
Aug 24, 2004 02:19 PM
accordfreak
Mar 12, 2003 09:42 PM
