car wont go into gear
Old Jun 3, 2006 | 10:32 AM
exotik4doorcivic's Avatar
Default car wont go into gear
my friend has a civic hb with a gsr in it he is having problems with putting his car into gear
when he pushes in the clutch with the car on it wont go into any gear when it does this he has top shut the car off put it in gear then turn the car on and it will king of jump like its being forced into gear
but then sometimes it goes in fine shifts fine and works great
its a reacurring problem
he replaced the clutch master cylinder, and we bled the lines
Old Jun 3, 2006 | 11:02 AM
RaceMyGhost's Avatar
Default Re: car wont go into gear (exotik4doorcivic)
this is a typical teg tranny problem.....u dont have to turn the car off and restart it, simply release the clutch pedal and push it again or just put it into 2nd and then back into 1 and it will slide right in
Old Jun 3, 2006 | 11:15 AM
SuzukaBlueAP2's Avatar
Default Re: car wont go into gear (RaceMyGhost)
I had an Integra for 4 years and didn't have this "Typical" problem
The only time I had an issue that is close to what you are describing is when I broke my clutch disc. If you break the disc or the springs in the hub, you will have trouble getting in and out of gear.
Old Jun 3, 2006 | 01:48 PM
Default Re: car wont go into gear (ScreaminTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScreaminTeg &raquo;</TD></TR><TR><TD CLASS="quote">I had an Integra for 4 years and didn't have this "Typical" problem
The only time I had an issue that is close to what you are describing is when I broke my clutch disc. If you break the disc or the springs in the hub, you will have trouble getting in and out of gear.</TD></TR></TABLE>
i have a brand new master/ slave cylinder (OEM), brand new clutch, flywheel and brand new bearings. my entire system has been bleed and i still have this TYPICAL problem. whoever i have spoke to that owns an integra has this problem every now and then.
Old Jun 3, 2006 | 01:55 PM
nocturnal EG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RaceMyGhost &raquo;</TD></TR><TR><TD CLASS="quote">this is a typical teg tranny problem.....u dont have to turn the car off and restart it, simply release the clutch pedal and push it again or just put it into 2nd and then back into 1 and it will slide right in</TD></TR></TABLE>
this usually works for me when i have trouble getting in gear.
Old Jun 3, 2006 | 02:04 PM
FULL-REV's Avatar
i'm thinking its a bad tranny linkage
Old Jun 3, 2006 | 02:53 PM
kpop's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exotik4doorcivic &raquo;</TD></TR><TR><TD CLASS="quote">my friend has a civic hb with a gsr in it he is having problems with putting his car into gear
he replaced the clutch master cylinder, and we bled the lines </TD></TR></TABLE>
when was the last time he replace the clutch.
Old Jun 4, 2006 | 07:49 AM
Default Re: car wont go into gear (kpop)
the thing about his clutch though is it still grabs hard. he put the engine in about 6 months ago so the clutch isnt that old
when you turn the car off you can shift in the gears fine but when the engine is running he can go into any gear at all
Old Jun 4, 2006 | 09:17 AM
gsr dood's Avatar
i got my money on a bent or loose shift linkage. jack up ur car and have a look.
Old Jun 4, 2006 | 10:55 AM
CleanLikeJdm's Avatar
Hype-R Stalker
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exotik4doorcivic &raquo;</TD></TR><TR><TD CLASS="quote">when you turn the car off you can shift in the gears fine but when the engine is running he can go into any gear at all</TD></TR></TABLE>
I had a spring popping out of the clutch disc when I had a similar problem like that,
All of a sudden it was horrible to get into gear, but did slightly better when off.
Not exactly a "teg" issue only, it happens on other cars/trucks too.
Old Jun 4, 2006 | 11:00 AM
Insomnian's Avatar
weird.
Old Jun 4, 2006 | 11:02 AM
Default Re: car wont go into gear (gsr dood)
we checked the linkage it was tight and not bent
and if it was the linksge why would it go into gear with the car off??
Old Jun 4, 2006 | 10:47 PM
xXLiGhTsTyp3RXx's Avatar
I'm having this problem too.. but i know what's wrong with my tranny. it's my 1,2,3 gear synchro's that have cracked... so that might be one of your problems too..
Old Jun 5, 2006 | 12:04 AM
sinister357's Avatar
mines was doing that for awhile on and off and eventually can't shift into gears anymore if the engine was running and the car not moving. the clutch is on constantly - like car jumping while starting. i had it checked out by several mechanics and they all determed it to be the clutch system. more the likely bent fingers i'm guessing. i havent fixed it yet but if i do and your problem presist, i'll let you know if mine is solved.
Old Jun 5, 2006 | 07:44 AM
Default Re: car wont go into gear (sinister357)
thanks, i aked my dad who is a mechanic and he said it could be the slave cylinder,pilot bearing or he said he needs to take longer to bleed the system and make sure there is no air
Old Jun 5, 2006 | 08:41 AM
95greenteg's Avatar
I have the same issue too...I'm contemplating replacing my clutch because of this....Not sure of what else to do....
Old Jun 5, 2006 | 09:16 AM
db8gsr_teg's Avatar
maybe you should change the tranny fluid, this happen to me once. If its not the tranny fluid then its the synchros.
Old Jun 5, 2006 | 09:19 AM
Hype-R Stalker
Yeaaah so .. Split the tranny off the block, and then you know whats wrong, more then likely.
Old Jun 6, 2006 | 03:47 AM
95greenteg's Avatar
Default Re: (db8gsr_teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by db8gsr_teg &raquo;</TD></TR><TR><TD CLASS="quote">maybe you should change the tranny fluid, this happen to me once. If its not the tranny fluid then its the synchros. </TD></TR></TABLE>
I've tried this already...
Old Jun 6, 2006 | 11:36 AM
triple's Avatar
This has happened to me when going into 1st. I found the quickest rememdy was just to put it into 2nd then it slides easy right into 1st.
This also happens to me when I try and put it in reverse, happens alot more then shifting into 1st.
Old Jun 10, 2006 | 06:36 AM
95greenteg's Avatar
Default Re: (triple)
I've decided I'm going to go ahead and replace my clutch/pressure plate/bearing. I'll let you guys know wether that worked or not...
Old Jun 10, 2006 | 07:26 AM
Mach2ek4's Avatar
Default Re: (95greenteg)
I had the same problem.... replace the clutch and your problems should go away...
Old Jun 10, 2006 | 03:11 PM
nebulight's Avatar
Default Re: (Mach2ek4)
I have the same issue, I'm going to replace the Master and Slave when the part gets here, and I hope that will fix it. I don't think it's the clutch, because when it is in gear, the clutch holds up fine.
Old Jun 11, 2006 | 07:12 PM
95greenteg's Avatar
Default Re: (nebulight)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nebulight &raquo;</TD></TR><TR><TD CLASS="quote">I have the same issue, I'm going to replace the Master and Slave when the part gets here, and I hope that will fix it. I don't think it's the clutch, because when it is in gear, the clutch holds up fine.</TD></TR></TABLE>
Let us know what happens...I did not get to fix mine this weekend...Forgot to take the flywheel to get re-surface in time...Hopefully replacing my clutch this week and will be posting results...
Old Jun 11, 2006 | 07:25 PM
Duster's Avatar
I had this problem as well. Id say its a typical integra or any japanese made car.
Ive heard it something to do with very small shifting ranges, but when i say taht it doesn't make a lot of sence.
Skeero
Transmission & Drivetrain
Oct 18, 2011 07:23 AM
scrEaMO Kyle
Nov 3, 2005 03:43 PM
Rocks.
Aug 22, 2005 03:12 PM
CWTegRNo.160
Jul 27, 2005 03:25 PM
