Car isn't starting... need help
Old Jun 3, 2006 | 10:16 AM
Chief Brody's Avatar
Do it right the first second time!
Community Builder
Active Streak: 30 Days
Default Car isn't starting... need help
Well, my Prelude has been acting up lately.
Sometimes I'll just go hop in the car, fire her up, and take off. But, there are times when I'll go to start it and it will just sit there and crank, but not turn over.
Also, I don't know if this is a mental thing, but it seems that the car only does this when it's hot out?
Also, I can crank it for 10 minutes and nothing will happen, then 10 minutes later I can try again and it will fire right up.
Any help would be appreciated
Old Jun 3, 2006 | 11:12 AM
jdmlude_dude's Avatar
Default Re: Car isn't starting... need help (Chief Brody)
main relay
Old Jun 3, 2006 | 10:32 PM
Community Builder
Default Re: Car isn't starting... need help (apeng09)
Cool. I'll check it out tomorrow. Thanks guys
Old Jun 4, 2006 | 07:18 AM
SKDRCR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by apeng09 &raquo;</TD></TR><TR><TD CLASS="quote">aka ignition switch</TD></TR></TABLE>
umm, actually they're 2 different parts.
sounds like the trademark symtoms of a main relay.
could possibly you're ignition module in your distributor though.
Old Jun 6, 2006 | 12:50 PM
Community Builder
Default Re: Car isn't starting... need help (SKDRCR)
Does anyone know what product number it is? Or where I can find it on hondaautomotiveparts.com?
Old Jun 6, 2006 | 01:04 PM
Jagan'92's Avatar
slhondaparts.com
http://slhondaparts.com/browse...0-003
I had the same problem at one time - there is a way to delay the problem by taking the relay out and resoldering the contact points.
search prelude archives for "main relay"
Old Jun 6, 2006 | 01:32 PM
Community Builder
Default Re: Car isn't starting... need help (Jagan'92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jagan’92 &raquo;</TD></TR><TR><TD CLASS="quote">slhondaparts.com
search prelude archives for "main relay" </TD></TR></TABLE>
Awesome. Thanks a lot man
Old Jun 6, 2006 | 06:53 PM
jzobie1's Avatar
And no you arent going crazy it will act up more when it is hot.
Old Jun 6, 2006 | 07:06 PM
draconx's Avatar
try cycling the ing. like turn it on (not crack) then off and then on off on off and then try to crank it. ur fuel pump MIGHT be going out
Old Jun 6, 2006 | 08:09 PM
prelude1897's Avatar
Default Re: Car isn't starting... need help (draconx)
There was a recall on the ignition switch. Just go to your nearest Honda Stealership and they can tell you if you car was one of the many in that recall and replace it for FREE
Old Jun 6, 2006 | 08:24 PM
Community Builder
Default Re: Car isn't starting... need help (prelude1897)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelude1897 &raquo;</TD></TR><TR><TD CLASS="quote">There was a recall on the ignition switch. Just go to your nearest Honda Stealership and they can tell you if you car was one of the many in that recall and replace it for FREE</TD></TR></TABLE>
Right on, I didn't even think about that.
If that doesn't work, I have found that punching the steering wheel actually starts it. But, with my luck, the car will retaliate and deploy the airbag into my face
Old Jun 9, 2006 | 06:10 AM
attentionwhore's Avatar
From: ...and then along comes the fcuking policia, PA
No, dont waste your money on the ignition switch....it is definatly the MAIN RELAY. I just had this happen in my 89. When its hot out the solder on the main relay melts somewhat and separates thats why the car wont start. Go here for the full fix. Under common problem fixes, third one down.
http://prelude3g.com
Good luck its easy on takes about 45 minutes to fix.
Old Jun 9, 2006 | 06:15 AM
mic907's Avatar
just a simple suggestion, make sure you don't need to jsut replace your battery. My car was giving me the same sort of crap for months until it finally wouldnt start at all. but once i replaced the battery, all was well.
popthatclutch13
Sep 20, 2018 03:12 AM
deguzmanEG
Oct 31, 2008 01:32 PM
rb_888
Jun 17, 2008 03:51 PM
Mr.Death
20
Aug 27, 2006 10:52 AM
