pic request itr with nsx wheels
Old Jun 3, 2006 | 10:03 AM
roc's Avatar
roc
Default pic request itr with nsx wheels
anyone seen it done yet
Old Jun 3, 2006 | 12:59 PM
Mires's Avatar
Default Re: pic request itr with nsx wheels (roc)
Its been done but it seems all the pics that was posted before are gone now. Im sure someone on here has pics saved on their comp. I might have one saved on cd-r. Ill see if I can find it.
Old Jun 3, 2006 | 01:08 PM
Bradstard's Avatar
Baby NSX has them. All of his pics aren't working as Mires said. I might have some pics on my home PC. IMO, they look great.
Old Jun 3, 2006 | 01:28 PM
330R's Avatar
I hope Baby NSX doesn't mind. (I save practically all ITR pics )
Looks great. IIRC you have to use two sets of the front wheels for proper fit on an R. Maybe someone can confirm.
Old Jun 3, 2006 | 01:39 PM
vivid 02's Avatar
Default Re: pic request itr with nsx wheels (Bradstard)
Old Jun 3, 2006 | 02:11 PM
roc's Avatar
roc
Default Re: pic request itr with nsx wheels (330R)
thankx for the pics,i guess i'll start searching for 2 pairs of nsx front rims.
Old Jun 3, 2006 | 03:23 PM
Mires's Avatar
Here's a couple more.
^^ That ones kind of small but you get the idea. Hope the owner doesn't mind.
Old Jun 3, 2006 | 03:30 PM
itr1244's Avatar
Default Re: pic request itr with nsx wheels (Mires)
it looks sweet with nsx rims .. looks nice and clean
now powder coat them flat black
Old Jun 3, 2006 | 09:12 PM
vivid 02's Avatar
Default Re: pic request itr with nsx wheels (vivid 02)
Is it possible to powder coat rims Championship White???
Old Jun 3, 2006 | 10:54 PM
.C h r i s's Avatar
looks so nice, what size are nsx's? 17? anyway, i wonder how thoes would look in CW
Old Jun 3, 2006 | 11:02 PM
KOALA YUMMIES's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vivid 02 &raquo;</TD></TR><TR><TD CLASS="quote">Is it possible to powder coat rims Championship White??? </TD></TR></TABLE>
Old Jun 3, 2006 | 11:22 PM
Try2Live4God's Avatar
Default Re: pic request itr with nsx wheels (KOALA YUMMIES)
Those look real nice on a Type R!!
Old Jun 4, 2006 | 12:47 AM
JjuuN R's Avatar
Default Re: pic request itr with nsx wheels (Try2Live4God)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Try2Live4God &raquo;</TD></TR><TR><TD CLASS="quote">Those look real nice on a Type R!! </TD></TR></TABLE>
x2
Old Jun 4, 2006 | 03:01 AM
Circuit Star-29's Avatar
What is the offset of the front NSX wheels?
Old Jun 4, 2006 | 07:22 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: pic request itr with nsx wheels (Circuit Star-29)
The offset on the front NSX wheels is 55 mm (it's 60 mm for the rears). The bigger problem for using NSX wheels on the ITR is the center bore (that's the big hole in the center of the wheel). The ITR uses wheels with a 64 mm center bore, which is what the NSX rears have, but the NSX fronts have a 70 mm center bore. You'll need to find a set of hubcentric rings to use NSX front wheels on an ITR (and finding them is next to impossible, unless you know of someone who can machine them for you); otherwise, the lugs will bear the entire load of centering the wheels. Some people find that it works out, but a lot of people who use wheels with an oversized center bore end up with vibration problems because of the loss of the hub for wheel centering. (That's true not just of the ITR, but of many other cars as well.)
I had thought about using NSX wheels on my ITR for track tires, so that I could swap track tires between the two cars using the same wheels. Because of the problem with different center bores and the difficulty finding metal hubcentric rings, I eventually gave up on the idea.
Old Jun 4, 2006 | 09:20 AM
Default Re: pic request itr with nsx wheels (nsxtasy)
The hub centering problem is a minor minor issue and pops up in the roadracing/autocross forum all the time. The concensus is that friction between the hub and wheel holds the wheel, while the hub centering rings and wheels are merely to make it easier to bolt the wheel down, ensuring the lugnuts are making proper contact with the wheel. If you take your time with overbored wheels when tightening the lugnuts down its not really an issue.
Old Jun 4, 2006 | 09:26 AM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KOALA YUMMIES &raquo;</TD></TR><TR><TD CLASS="quote">If you take your time with overbored wheels when tightening the lugnuts down its not really an issue. </TD></TR></TABLE>
Like I said, some people don't have vibration problems with overbored wheels, but a lot of others do, even after being very careful and following all the proper procedures when tightening the lugs. Like anything that might or might not be a problem, it's a risk, something that may or may not happen in any particular case. I didn't want to take that risk.
Old Jun 4, 2006 | 12:48 PM
nholmes's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mires &raquo;</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>
for yellow recaros
Old Jun 4, 2006 | 03:23 PM
Solscud007's Avatar
Default Re: pic request itr with nsx wheels (nholmes)
is it jsut me or do the NSX wheels look like ITR rims?
Old Jun 4, 2006 | 03:38 PM
vivid 02's Avatar
Default Re: pic request itr with nsx wheels (Solscud007)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Solscud007 &raquo;</TD></TR><TR><TD CLASS="quote">is it jsut me or do the NSX wheels look like ITR rims?</TD></TR></TABLE>
NSX rims are 16 in
Old Jun 4, 2006 | 04:42 PM
nsxtasy's Avatar
H-T Order of Merit
Incidentally, for anyone considering this, the '94-96 NSX wheels were painted gunmetal color almost identical to the '00-01 ITR wheels, and the '97-01 NSX wheels were a clearcoated brushed aluminum. All the photos above are of the '97-01 NSX wheels. White wheels were also available on an optional basis but were very rare.
Used NSX wheels are most commonly available in sets of four, two fronts and two rears, and typically go for $750-1500 a set depending on condition (and that's without tires, can go for more with tires). Note that these are NOT the five-spoke '91-93 NSX wheels that sometimes go for under $200 a set.
New front wheels and prices:
'94-96 front 16x7 Solaris Silver (gunmetal) 44700-SL0-A01ZA list $1204.95 each, Delray Acura $963.96 each
'94-96 center cap Solaris Silver (gunmetal) 44732-SL0-A02ZA list $61.13 each, Delray Acura $48.90 each
'97-01 front 16x7 Blades Silver (brushed aluminum) 44700-SL0-A30ZA list $1204.95 each, Delray Acura $963.96 each
'97-01 center cap Blades Silver (brushed aluminum) 44732-SL0-A30ZA list $37.82 each, Delray Acura $30.26 each
What's funny is that the photos are of the '97-01 wheels. The '94-96 NSX gunmetal seven-spoke wheels look even more like the ITR '00-01 gunmetal seven-spoke wheels, except for the size.
Old Jun 4, 2006 | 04:58 PM
OT I've always loved the wheels on the first NSX Type Rs (1992-1995 I think, and super rare). But I've always been curious of what those wheels would look like on a CW
If anyone can find a pic post it up, they're a 5-spoke design painted in CW (I've been looking).
Old Jun 4, 2006 | 05:23 PM
330R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KOALA YUMMIES &raquo;</TD></TR><TR><TD CLASS="quote">OT I've always loved the wheels on the first NSX Type Rs (1992-1995 I think, and super rare). But I've always been curious of what those wheels would look like on a CW
If anyone can find a pic post it up, they're a 5-spoke design painted in CW (I've been looking).</TD></TR></TABLE>
I don't have a pic of the wheels on a CW ITR, but here are the wheels in question, from the rare parts thread in A/C:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by icbmatt &raquo;</TD></TR><TR><TD CLASS="quote">
Old Jun 4, 2006 | 10:31 PM
Solscud007's Avatar
I would like to see Zanardi rims on an ITR.
Old Jun 4, 2006 | 10:33 PM
.C h r i s's Avatar
Default Re: (Solscud007)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Solscud007 &raquo;</TD></TR><TR><TD CLASS="quote">I would like to see Zanardi rims on an ITR.</TD></TR></TABLE>
zanardi rims are choice
