convert dpfi to mpfi then odb0 to obd1
Old Jun 3, 2006 | 07:58 AM
remoer's Avatar
From: fountain inn, sc. where they still rock banjos on porches, usa
Default convert dpfi to mpfi then odb0 to obd1
well just as the heading says. i've ask this question before but damd i must be dumder then a box of rocks, i'm still a little lost.....
in my 90 crx dx is dpfi. ok i understand that.
now putting on a 90 si mpfi. is to convert. again i understand that and the process. this is where it turns foggy.
i want to put a d16z6 intake with all the part as in a mpfi convertion. but is it possible to used a odb0 to odb1 ecu jumper so i can run a p06 ecu. so i can later on down the road chip the p06 ecu and used crome pro for the set of itb i have. which crome pro is easier to use in this platform.
parts i have to use in this n/a project...
d16a6 block w/p29 piston - just bought it.
d16a6 tranny that i want to put a lsd in(still trying to decide between a zc or and a6 tranny i have access to both and a z6 tranny too)
d15b7 head- rebuilt, pnp
d16z6 intake portmatch to a teg tb 60mm.
d16a6 cam, zc cam and a 272 delta regrind cam - which i'm debating which on to use(the 272 is on the top of the list)
edelbrock ajustable cam gear
p06 ecu - virgin and free(but i can get the ecu for a 90 crx si or the p28 if i want, again i have acess to buy it)
cbr600rr itb - which i will used one i can get this mess to work lol.
maybe showing the parts and what i'm trying to do, can help answer these question. i've tons of research(over the last 3 monthes) but the answers are not persice to my question.
bluesi00
Oct 18, 2005 04:42 PM
Conclusive
May 30, 2005 11:06 AM
The DX Rex
Oct 8, 2004 12:08 PM
FireMedic
May 8, 2003 06:05 AM
CRX A4
15
Sep 17, 2002 09:51 PM
