Failed Horribly :(
so i took my CRX into honda the other day to get it safety and E-tested.. and it failed the E-test HORRIBLY!! i dont get it.. it failed in every catagory by like triple the allowable amount!! and the safetly failed also cuz the windshield is cracked on the passenger side a bit and there are rust holes in the spare tire wheel well i guess that i need to get fixed.. which isnt SOO bad i guess since those parts dont need to get painted or anything.. still pised though! lol have to toss in more omney than expected to get this damn thing on the road!
Well I can try to help you out on the E-test. All honda's fail because of mostly three things.
1. Cat
2. O2 sensor
3. Carbon build-up (On pistons and EGR passageways)
And the fourth would be EGR problem either the vac soleniod or EGR valve(If you have one)
And make sure the timing is correct. And your tune-up is good.(Plugs, wires, cap, and rotor.
Doesn't it suck! It seems that they want us to give up our cars because they think it a POS. Give them the finger when you are done and passed.
Mind if I ask you for your limits? I want to compare CA limits to yours.
1. Cat
2. O2 sensor
I agree with the smog man. Check out the O2 sensor first... its pretty easy to do, and cheap to replace. Then check out your cat.. easy to check out, more expensive to replace. In this case I'd just go ahead and replace the whole exhaust system because its probably gonna be in horrible condition as well (unless this is going to be a beater car or something, then don't bother unless it's REALLY bad).
Change out the oil and fuel filters if they haven't been for awhile. Do an oil change and top up with good stuff. Replace the spark plugs and wires if they're old.
ewll apparently the B16a was just swapped in like a year or so ago.. so i figured it wouldnt be SOO bad.. but i guess not.. i went out today to buy some new plugs, cap and rotor, and some oil and an oil filter and also picked up some "gauranteed to pass" stuff LOL this is what honda recommended. I figured they would just pass me anyway atleast on the safety and just tlel me to make sure I get it fixed.. since i used to work there.. LOL GUESS NOT!
as far as whoever said that O2 sensors are cheap to replace?? where did u get urs! lol in my 97 civic an O2 sensor costs almost 300 bucks! unless they are cheaper for OBD-0 cars
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dxcivic »</TD></TR><TR><TD CLASS="quote">as far as whoever said that O2 sensors are cheap to replace?? where did u get urs! lol in my 97 civic an O2 sensor costs almost 300 bucks! unless they are cheaper for OBD-0 cars</TD></TR></TABLE>
yes they are cheaper, they are only 1 wire and a new bosch one cost less than $50
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy »</TD></TR><TR><TD CLASS="quote">
yes they are cheaper, they are only 1 wire and a new bosch one cost less than $50</TD></TR></TABLE>
oh really?? sweet! i like the sounds of that!.. but now if there is something wrong with the O2 sensor wouldnt it throw a code?
Not all the time you can have a slow one or a bias one without tossing a code.
Just not driven to failure limits!
Come on give me your numbers on the emissions part.
We failed badly our stock 1.5L D15B2 once...all we did was change the air filter and she passed haha.
EDIT: Your from stratford? IM me or email me and we can see about making your bitch pass.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by square_1 »</TD></TR><TR><TD CLASS="quote">That is one thing I love about Oregon... Emissions test? What's that? Haha.</TD></TR></TABLE>
thanks a lot *******
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by temp »</TD></TR><TR><TD CLASS="quote">post the picture of your smog sheet. until then, no one reply.</TD></TR></TABLE>
who cares
b16a1 has 2 o2 sensors, make sure that 1. they are wired correctly and 2. then worry about replacing them
also, make sure that honda is testing your car under "hot rod" because it has a non stock motor.
hotrod has FAR less requirements then 88-91 a.6l Honda Civic/CRX. if they tested it under normal then i would tell them to do it again for free since they did it wrong.
here's a pic of the OEM B16a1 header w/ both o2 sensors.
who cares
hotrod has FAR less requirements then 88-91 a.6l Honda Civic/CRX. if they tested it under normal then i would tell them to do it again for free since they did it wrong.here's a pic of the OEM B16a1 header w/ both o2 sensors.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si »</TD></TR><TR><TD CLASS="quote">
who cares
who cares? wtf? you serious? we need that **** to see his exact numbers to pinpoint his problem(s). you cant always assume its the O2 sensor causing the problem.
who cares
</TD></TR></TABLE>who cares? wtf? you serious? we need that **** to see his exact numbers to pinpoint his problem(s). you cant always assume its the O2 sensor causing the problem.
who cares? wtf? you serious? we need that **** to see his exact numbers to pinpoint his problem(s). you cant always assume its the O2 sensor causing the problem.</TD></TR></TABLE>
It's his O2...
It's his O2...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">it failed in every catagory by like triple the allowable </TD></TR></TABLE>
thats good enough for me. besides, i wasnt telling him it was the o2 sensors causing the problem. just indicating that if he were to replace them he would need 2 to be certain.
could be his cat, could be the wrong map sensor, could be the wrong ecu, could be a number of things. too many variables without the smog sheet.
I bet you it just needs a tune up. I've seen horrible failures to do to a bad tune. There are easier way to make it pass...leaning it out...I think we used to advance to the timing a bit...or was it retarding it...it's over 1 1/2 year since I got anything e-tested so I'm a little confused as to what we did.
Oh we also put stock header and cat on. If you have aftermarket header and high flow cat, replace with original.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv »</TD></TR><TR><TD CLASS="quote">I bet you it just needs a tune up. I've seen horrible failures to do to a bad tune. There are easier way to make it pass...leaning it out...I think we used to advance to the timing a bit...or was it retarding it...it's over 1 1/2 year since I got anything e-tested so I'm a little confused as to what we did.
Oh we also put stock header and cat on. If you have aftermarket header and high flow cat, replace with original.</TD></TR></TABLE>
but it really depends on all the variables that we dont know lol.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lost_in_a_world_so_cold »</TD></TR><TR><TD CLASS="quote">$200 smogged lol</TD></TR></TABLE>
being gay and doing things illegally is not smart. please die, in a fire. today.
You can do that. But little does he know that cops in Ontario are pulling Blitz. They basically target 'supped up cars'. The rice and the nice looking honda mostly. They harass you large about all your mods. That's why I'm keeping stock exhaust. Stock everything. I get followed by cops and they don't even car cause I have a spray painted civic with alot of shittyness about it. Yet I can rock out alot of other cars with it.
And a part of the Blitz is road side e-testing...they also check for cats, resonators and mufflers. They also check for charcoal canisters and working O2 sensors. You are missing anything, or fail the road side etest, you lose your valid sticker on your license, and must usually re-safety and re-etest the car. After that you need to pay the fines, and then you need to buy a new sticker for your license. A fake etest fine is 125000$ last time I checked.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv »</TD></TR><TR><TD CLASS="quote">And a part of the Blitz is road side e-testing...they also check for cats, resonators and mufflers. They also check for charcoal canisters and working O2 sensors. You are missing anything, or fail the road side etest, you lose your valid sticker on your license, and must usually re-safety and re-etest the car. After that you need to pay the fines, and then you need to buy a new sticker for your license. A fake etest fine is 125000$ last time I checked.</TD></TR></TABLE>
Damn! Move to VA!
Damn! Move to VA!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman »</TD></TR><TR><TD CLASS="quote">
Damn! Move to VA!
Nah, too many pretty ladies here...
Damn! Move to VA!
</TD></TR></TABLE>Nah, too many pretty ladies here...
