LS vtec sleeved 85mm je pistons rpm rods made 323hp @ 201 tq with dyno sheet
Old Jun 3, 2006 | 12:44 AM
gofastcrx's Avatar
Default LS vtec sleeved 85mm je pistons rpm rods made 323hp @ 201 tq with dyno sheet
up for sell is my ls vtec bottom end with aebs sleeves closed deck good for big boost or crazy all motor nothing is wrong with it what so ever has only 3000 miles on it just built. it has je pistons at 12.5:1 with an 85mm bore, RPM I beam rods, everything was balanced and blue printed. i blued printed the block myself. i use to work for inlinefour they call me timebomb i was the tech there. i am willing to just sell the block if that all u want. i can sell just the bare block. hit me up for ? shot some offers
Old Jun 3, 2006 | 08:10 PM
gofastcrx's Avatar
bump
Old Jun 4, 2006 | 09:37 AM
gofastcrx's Avatar
up
Old Jun 4, 2006 | 09:28 PM
gofastcrx's Avatar
bump
Old Jun 11, 2006 | 04:48 PM
gofastcrx's Avatar
someone much want a motor with some power
Old Jun 13, 2006 | 03:41 PM
gofastcrx's Avatar
check the link now. but here the run down on it. i had it for about 3000 miles it has je pistons with rpm I beam rods, crank was balanced and polished, used all honda bearing. i blue print it myself. i used to work for inlinefour they call me timebomb. it also has a new itr oil pump and water pump. the sleeve are done by aebs as u can see its closed deck. it runs great nothing is wrong with it. i took the head off the motor to put a thicker head gasket so i can run a lil less compression but what happen was the head stud treads pulled out so i had to take the motor out and i pay good money to have the treads redone with time inserts which is stonger then stock so it wont happen again . there was only one head stud that was messed up but i had then put all 10 so it will never happen again. it cost me 200 to get that done.
tread inserts $200
block sleeved $1100
block $200
piston ere spec. $650 i didnt get a break on these cause i got them 3 year ago
rpm rods $300
balanced everything $200
honda bearings &200
assemble labor
and time to measure
block $400 but i did it so its free
thats $2850 with out labor on the block
with labor its $3250
the reason i'm getting rid of it is because i had to pull the motor out so i decied to build a turbo motor. my plan was to go turbo but not now. so since i have my motor out i changed my plans. it ran 12.5 with 252 hp on a raining day at fontana, only got 2 runs. and on a hot day and high elavantion at palmdale it ran all motor 13.0's so at fontana it should run .5 seconds faster to hit 12.6 ets. in my civic with full interior and a/c it made 232 hp allmotor but i run it at 9 dergees of timing with the nos. i never ran it with the 2 stage NOS where it made 323hp i was trying to but this happen so i just want some money to build my next project.
LOOKING TO GET 2000OBO shoot me an offer low ball or not all i would say is HELL NO. i can show you my credit card bill for this motor. i still owe 2700
Ran4it2
Feb 10, 2009 12:18 PM
skiracer8148
Jul 7, 2007 05:45 PM
gofastcrx
Jun 4, 2006 11:30 PM
LSR-Abuser
May 9, 2005 01:15 PM
