teg stalls out when i give it gas?? help
ok so i just dropped back in the fully built lsvtec
iam trying to break it in before tune.
I currently have it with
stock headers
stock fule rail
stock injectors
msd external coil and dizzy.
it starts with a rough shakky idle
when i give it gas, as its coming down it dies.
i have to keep the revs up to keep it alive.
I swapped my friends b16 dizzy on there and it helped a lil.
idle was ok, just a lil rough and when i gave it lil gas it kind of caught it self and stayed runing. but when i give it a big rev ( 3k) it died on the way down agian.
iam stumpped, could this be a timing problem or injectors are crapped out.
its a
84 mm sleeved block
9:1 je
b16a2 head
no thermostat
no intake
p28 ecu
stock ls injectors
running open headers for the break-in.
should i just try the turbo on there for the break-in.
stock headers
stock fule rail
stock injectors
its a
84 mm sleeved block
9:1 je
b16a2 head
no thermostat
no intake
p28 ecu
stock ls injectors
First thing I would do is ditch MSD crap. Not necessary unless you are making 400+ WHP.
Do you get any check engine codes?
I would check the timing and go over ALL of your electrical connections to make sure they are right as well as snug.
yea actually iam going to 500 hp.
I have took off my MSD 6al, i am just using the external blaster coil.
But i swapped out whole dizzy for a friends STOCK b16 dizzy, and same problem.
My wiring connections is right, and i do get a check engine, but its for vtec pressure switch.
haven't installed 1 yet, cuz i was running a JDM solenoid.
Due you think the stock LS injectors can't hold up the 84mm bore with 9:1 pistons.
I also tried reseting the ecu and still same problem.
u used timing light after swapping dizzys?? b/c u need to set timing at 15degrees
and your tps voltage needs to be set at
.45-.5 v at closed throttle and 4.6-5v at WOT
u loosen the 2 srews and move it back and 4th, unless its rivted on in which case u have to cut a slot in them and use a flt head screw dirver to adjust it
this deffinately sounds like ur problem
car doesnt need to be running
i had no idea how many people didnt know this
