anyone know how to put dsm injectors in a civic? Help!!!!
1. Remove fuel line from fuel rail
2. Remove fuel return line
3. Remove the 3 10mm nuts holding the fuel rail
4. Remove injector clips
5. Remove fuel rail (more then likely the injectors will come with)
6. Put in new injector seats (bored out for the new injectors) into manifold
7. Place new injectors in fuel rail
8. Put fuel rail back onto manifold
9. Wire up resistor box, or resistor packs (10ohm)
10. Have a beer
11. Remember to put all the fuel lines back on too.
10. Have a beer
i assume you're gonna get your ecu tuned on these new injectors....otherwise it'll run like crap and be detrimental to what you are trying to achieve....
B16Jacques
Jun 15, 2005 08:25 PM
