removing powersteerin/ AC
i was j/w if anyone has the steps to taking out ur powersteering an a/c. i havent had any experiance with this setup. if anyone could tell me what i do with the belt an what to take out an all that good stuffs.. pics would be Nice.. would love to see some pics thanks
To start off you must take off the alternator two bolts one over top and one under the alternatorloosen them and on the front between the ac comp and alt there will be two small bolts that is to adjust the alt loosen that till you can get the alt belt loose. Then take out the alt and you can get to theac comp four bolts at each corners and then replace in the oposite direction and then get your alt belt without ac 9 bucks at autozone and then cut up the lines and slip them out with the bumper off and take out the condenser and there you go you lost bout 30 lbs and gained bout 5hp
Modified by BlUAc at 10:27 AM 6/3/2006
oh and ya you dont want to take out the powersteering the fluid lubes up the rack and pinion if you take it out it will over time seeze up on you but there is a way I have seen with a small clutch master cylinder reservoir with some stainless steel lines
