car wont start, code 20'
i have a code 20 and the car wont crank over
fuel pump comes on and whines when i try to start but wont crank anything'
whats code 20?
ive got a 93 del sol si with a 00 jdm itr swap
btw: this code randomly came on a week ago when i had some exhaust work done and then a day or so later i had an electrical fire near my battery because of a short with my distribution block, sense then i just re-wired everything with fresh wire and added a 200amp circuit breaker'
code 20 remains and now it wont crank over'
whats code 20?
hey man when you redid the wiring did you happen to take out the fuse box and unplug that wire from underneath?? I'm like 99.9 % thats for the eld and your car wont turn over unless thats taken care of.. hope it helps
i dont believe so'
can you get me some more information on this? im a wiring retard so some good info would be bitch
thanks man
you talking about the fuse box under the hood? mine is still there. Which fuse/wire do i need to remove?
thanks man
