Oil leak on B16A, not the spool valve gasket!?
Old Jun 2, 2006 | 04:49 PM
hella_usdm's Avatar
Default Oil leak on B16A, not the spool valve gasket!?
My friend has a 94' civic hatchback with a jdm swapped B16A and its been leaking around the vtec solinoid and we replaced the "spool filter gasket" and that apparently didn't do a damn thing since its still leaking. The oil kinda pools up on top of the tranny and its hard to find where its leaking from but we've narrowed it down to somewhere around the vtec solinoid. I'm more familiar with h-series motors (non-vtec) any suggestions?
Maybe #25 or 14??
Old Jun 2, 2006 | 04:51 PM
CivicVX94's Avatar
Default Re: Oil leak on B16A, not the spool valve gasket!? (eluderman)
sounds like the cam seal to me
Old Jun 2, 2006 | 04:57 PM
Archidictus's Avatar
Unceasing Measure
Default Re: Oil leak on B16A, not the spool valve gasket!? (CivicVX94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicVX94 &raquo;</TD></TR><TR><TD CLASS="quote">sounds like the cam seal to me </TD></TR></TABLE>
x2 or the dizzy seal.
Old Jun 2, 2006 | 05:04 PM
hella_usdm's Avatar
its got an aftermarket cam seal (two or three o-rings) and the dizzy seal is fine, too.
Old Jun 2, 2006 | 05:09 PM
CivicVX94's Avatar
Default Re: (eluderman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eluderman &raquo;</TD></TR><TR><TD CLASS="quote">its got an aftermarket cam seal (two or three o-rings) and the dizzy seal is fine, too.</TD></TR></TABLE>
well ****............
wtf is the "spool valve gasket"?
it could be the valve cover gasket tho...try a new one and make sure you torque it down properly
Old Jun 2, 2006 | 05:25 PM
hella_usdm's Avatar
Default Re: (CivicVX94)
it could be the valve cover gasket tho...try a new one and make sure you torque it down properly</TD></TR></TABLE>
its #12 in the picture, its just a big gasket that goes between the head and the vtec solinoid. The valve cover gasket isn't it either, thats new too.
Old Jun 2, 2006 | 06:50 PM
jadugartir's Avatar
i had same problem, oil building up on tranny, so i thought my headgasket wasnt put in right, turns out it was just my distributor o-ring gasket ($2 from honda) and my valve cover gasket, both were leaking. replaced them and its been all good ever since. basically almost anywhere you leak oil up top is going to drain and accumulate there, due to the tilt of the motor and the way it sits.
yoffer
Aug 21, 2012 03:23 PM
Jdm John
May 30, 2011 05:11 AM
danielblushtein
Mar 16, 2009 12:33 PM
ZC88CRX
14
Aug 1, 2004 02:02 PM
PearlWhiteAccord
Jan 15, 2004 03:07 PM
