speedometer doesn't work anymore?
Old Apr 14, 2002 | 08:57 PM
crxzc's Avatar
Default speedometer doesn't work anymore?
my speedo cable has broke on my crx. the little wire that goes inside the cable snapped. does anyone know if i can get a new wire cable? do i have to grease the wire cable before i slid it into the cable housing.
my crx si pics:
http://members14.clubphoto.com/kev56...ner-2362.phtml
Old Apr 15, 2002 | 01:05 AM
balistic CRX's Avatar
Default Re: speedometer doesn't work anymore? (crxzc)
i dont think you can get a new wire cable for the whole speedometer, just go and buy the whole thing from a honda dealer should be like less than a 100 dollars. installing it should be simple to do.
Old Apr 15, 2002 | 03:01 PM
SiREF8's Avatar
Default Re: speedometer doesn't work anymore? (balistic CRX)
Go to your local Honda Dealer and get one, I bought one here in Tx for mine and it ran about $35.00+Tax. So it may be more in your area.
Old Apr 15, 2002 | 04:54 PM
EF9_R_Killa's Avatar
did you check to see if the sensor popped out the tranny? try that first before going to spend money..
Old Apr 15, 2002 | 07:33 PM
No More Civic's Avatar
Default Re: speedometer doesn't work anymore? (EF9_R_Killa)
I had that prob with my 3rd gen supra, all i had to replace was the first foot of the speedo cable that plugs into the tranny, it turned out that the plug broke on it, took $20 and about 10min to fix it. Because the speedo cable is in 2 sections, the one that plugs into the tranny about 1' which is the cheap one to replace and then the long one with can get expensive. So take off the end that plugs into your tranny and check that before you do anything else, you might end up saving alot of time and money as opposed to just going out and replacing the whole cable.
turbo-crx
Oct 24, 2008 06:44 PM
JLefevers
Apr 8, 2006 06:21 PM
JKingCivicSi
Jul 8, 2005 10:48 AM
lYellowDragonl
Jul 15, 2004 07:44 PM
1SIKCRX
Jul 14, 2004 10:52 PM
