wheel bearing
are the wheel bearings machined on on 95 ls 4dr?, my driver side one is making alot of noise, I thought it was my cv axel, so i replaced it last night, stll shakes and makes a noise that gets louder as I go faster any info / ideas?
they are pressed in cost around 80 for a new one + someone needs to press the old one out and a new one in maybe 20 or so, your looking at 100 bucks, another thought are u sure that your hub nut is tight enough, if you used an air gun go one or two more turns after you think its tight then tapp the nut into the axle end!! keep it posted!
