TPS Sensor???????
Today I started my car and checked to see if it was shooting any Error Codes and with my luck it was flashing code 7 which is TPS Sensor. I decided to swap the entire throttle body for one off an integra. I don't know which ones are compatible and if obd0/obd-1 TPS Sensors are the same. Can you guys help me out? Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aznlaoboi315 »</TD></TR><TR><TD CLASS="quote">Today I started my car and checked to see if it was shooting any Error Codes and with my luck it was flashing code 7 which is TPS Sensor. I decided to swap the entire throttle body for one off an integra. I don't know which ones are compatible and if obd0/obd-1 TPS Sensors are the same. Can you guys help me out? Thanks</TD></TR></TABLE>
what engine is it, the MIL came on out of the blue?
what can cause the TPS to malfunction? because there is a vacuum hose on the throttle body when removed causes my car to shoot black smoke but make my idle go down. When I put it back on the idle goes back up to 2500 RPM's. So what could be the problem and I tried 3 different throttle bodies.
