passing smog with jdm type r motor
i'm planning to do a jdm type r swap into my 94 gsr shell.....but i wanted to knoe is wat do i need to change from the jdm engine for it to pass smog after the swap....any info would be great thx
wat type of ecu the p72,p28,p73 and as for the manifold can i just use a skunk2 manifold to pass smog or do i need a b16a manifold or can i use a usdm type r manifold.....also wat type of header the 4-2-1 or the 4-1 and would a DC header do the trick or do i have to get a oem header.....lol sry if i'm asking so much question just i never delt with tis kind of swap before so i need some info about it.....any advice would be great thx.
the skunk2 manifold will pass smog... with that jdm ITR motor.. if u dont pass the first time.. id say u save yourself lots of headaches and get it "pass" for under the table
94RedEGCoupe
Jun 4, 2006 06:57 PM
