buffing carbon fiber?
Old Jun 1, 2006 | 10:07 PM
whiteb16's Avatar
Default buffing carbon fiber?
i have a very dull carbon fiber hood that looks like maybe its been just sitting in the sun too much. i was told it could be buffed out but was told it might need to use something other than regular wax. is there something special i should use for carbon fiber?
Old Jun 1, 2006 | 10:56 PM
Reza^'s Avatar
Default Re: buffing carbon fiber? (whiteb16)
it will last for three months and dull back to the oxidized state , you need to re-clear coat the hood again or buy a new one.
gl
Old Jun 1, 2006 | 11:44 PM
VTAC-KAT's Avatar
yea, reclear sounds about right
if you want you can wetsand it with some fine grit as a last resort to a respray but reclearing will have nicer results
Old Jun 1, 2006 | 11:45 PM
DUFFM4N's Avatar
Default Re: buffing carbon fiber? (auctionaccess)
there's some cleaner **** called marine *something* i forget the rest...seems to work pretty good, but like reza said...itll just go back to the way it is now after a while
Old Jun 2, 2006 | 08:45 AM
SiAutoX's Avatar
Default Re: buffing carbon fiber? (DUFFM4N)
I had a hood that was doing the same thing....and I wet sanded it with 800 then 1000 then 1500 then 2000 really good and buffed it real good with n electric buffer and it came out magnificant! and been good as new since (8 months ago). Just make sure you sand with the 2000 really good or you'll see little scratches when your done. I dont kno the exact condition of your hood, but I would definately try buffing before you spend all that money on gettin it re-cleared. total cost for me was about $31. not counting the cost of buffer.
Old Jun 2, 2006 | 09:02 AM
Chris.'s Avatar
Honda-Tech Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DUFFM4N &raquo;</TD></TR><TR><TD CLASS="quote">there's some cleaner **** called marine *something* i forget the rest...seems to work pretty good, but like reza said...itll just go back to the way it is now after a while</TD></TR></TABLE>
marine wax remover & then marine wax i believe. meguiars makes it
Fitz Williams
Paint and Body
14
Jan 27, 2013 02:06 PM
jrsh0526
Nov 1, 2011 03:48 PM
spray_bombed
25
Nov 20, 2007 03:12 PM
DV98CVC
Feb 27, 2003 06:09 PM
h22accordturbo
Jul 15, 2002 05:41 PM
