Questions regarding B16A Knuckle and Hub assembly for 91 CRX HF
I'm finishing off my b16 swap I started earlier in February. I've been off and on with this project, but currently, I'm up to this point: putting in the axle-shafts.
Does anyone know why I can't use my HF knuckle & hub? Does the Integra axle not fit through the HF hub? If I can't use the HF ones, then any other civic/crx ones will do, correct?
I read something regarding the Si-R tranny, that the Integra axle will not work and that I'll have to use the Si-R alxes.
Two axles came along with my B16A engine. I would assume these are the Si-R axles. Can I use these instead of buying Integra ones? And If I do use these, will they work with the CRX HF hubs?
Maybe I should just go in the garage and try out the axles? Man, so little time.
Well, if anyone of you can help, I would greatly appreciate it!
Correct the integra axles will not fit into the hf hubs. You will need either Si or dx hubs. If you have the Y1 transmission you will need to use SiR axles. If you have the S1 or J1 trans the 90-93 integra axles should work. Check the serial number on the trans to see which one you have. Also check out http://www.hasport.com/B16axles.htm for more axle information.
[Modified by 91civic, 11:16 PM 4/14/2002]
XMANZREX
15
Mar 9, 2007 11:13 AM
50shotRex
Feb 16, 2003 05:07 PM
