1984 CRX HF, runs drives but needs body swap, 300bucks takes it. around indianapolis, INDIANA
what it says... 84 honda CRX HF model.
trashed tires, totaly rusted out unibody! needs have the main shell replaced. OR use it as a field runner or what not......
motor is suposedly outta a newer 87crx HF but i have no way to know true milage outta it, it had a bad carb which i replaced with a rebuilt one, runs great now, shifts thru the gears great no grinds. 5speed manual.
just search around your local junk yards for one with a good body that has a bad motor/ trans which you should be able to get it for dirt cheap and put all the parts into the other crx shell.
i was going to do it myself BUT i ended up geting my 99civic instead and just had this thing parked since then!
300bucks takes it... but must be fully trailered due to the totaly trashed rubber! they do hold air BUT i wouldnt trust them on the road!!!!! and wouldnt trust the body on the road either!
comes almost complete, just missing rear hard bumper and brackets, and rear cargo cover door and rear carpet. so far to my knowledge everythings thier.
check out all my pics of it at
http://s40.photobucket.com/alb...084HF/
