stock front bumper?
may be the wrong thread, maybe should be in the appearance thread, but it can be moved.
i just want to know if this is the stock si front bumper and if those fog lights are stock as well? i am getting this can on sunday it is an 88 si and i already have a 91 si, my front bumper is bearly being held on and has a weird gash in it but looks dif. from this one as well... i just want to know if those fog lights are stock and if this will fit well on my 91? also will the hole front end support be the same as the one in my 91? looks as if previous owner of my car was in a fender bender and sent the pas. side front support a little, causing the pas. headlights to be pushed back a little. i dont have any picks of my 91, but here is one of the front of the 88
sorry if it is two wordy for you, i am new to the crx and even car world.
Modified by stemiched at 12:08 AM 6/2/2006
Those fogs/driving lights look like stock bosch units.
How to check? - First method is to look at the foglight lens and post up the serial number printed on the lens (should be LE........).
Second menthod is to remove the front bumper and check out the brackets holding the fogs on.
Thread I created a while back: https://honda-tech.com/zerothread?id=1496710
Let me know if you want to know the serial number too...I currently have the fogs mounted on my hatch and can check for you if you'd like.
**Dunno if those will fit on the 91's. Best way is to pull off your front bumper(s) to check. Takes maybe 5 minutes per bumper.
alright yea i probably will just take them both on and see if they fit, the bumper on my 91 is being held on by those plastic wire holder things... word seams to escaped my mind... i dont particularly like the fog lights like that... but maybe since there stock ill keep them there anyway, not sure yet.
yeah that bumper is a stock 88/89 si bumper but that person cut holes in it for the fogs..cause the 88/89 bumpers dont have holes but it is a 88/89 bumper going by the molding and bumper lights
Lets see whats different bewteen 88/89 and 90/91 frontend..
Bumper,corner lights,headlights/brackets,bumper lights,fender inserts for corner lights..What am i missing.?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stemiched »</TD></TR><TR><TD CLASS="quote">are you telling me that this front bumper wont work on my 91?</TD></TR></TABLE>
The bumper will work/fit..the moldings wont match the rest of the car though..
markv
Jan 18, 2004 12:46 PM
turbo sol
Aug 23, 2003 07:27 AM
RAWbertCuBus
Aug 8, 2003 07:00 AM
