Lowering 5th gen...having problem (searched)
Old Jun 1, 2006 | 07:15 PM
bb4socal's Avatar
Default Lowering 5th gen...having problem (searched)
Ok guys....i know this may seem like a dumb question but Im trying to find the answer to a question about lowering a 5th gen. Heres the suspension setup:
-Stock shocks
-Coilover Sleeves and Springs
-16" OEM rims and tires
A buddy of mine is having trouble lowering the car. He still has about an 1 or more from tire top to fender rim. We cant get the car to go any lower, as if the car was laying on the shock. What were trying to accomplish is having no gap between top of tire to Fender well. As i look through pics of 5thgens i see alot of guys tucking tire. All were trying to do is the same. I know most of you are saying GET AFTERMARKET SHOCKS. but he will, but not till we figure out this problem. IS there anything we should check?? has anyone else had this probleM?? Help me guys! thanks
Old Jun 1, 2006 | 07:16 PM
SteveoBA8's Avatar
Default Re: Lowering 5th gen...having problem (bb4socal)
Let me guess, ebay $10 coilover kit right?
Old Jun 1, 2006 | 07:18 PM
bb4socal's Avatar
Default Re: Lowering 5th gen...having problem (SteveoBA8)
Honestly...i dont know...they might be...but that should be the problem right?
Old Jun 1, 2006 | 08:08 PM
itsdatdncguysal's Avatar
is your friends 5th gen and sh?if so i was told you cant lower them as much as the base.
Old Jun 1, 2006 | 08:30 PM
bb4socal's Avatar
Default Re: (itsdatdncguysal)
no its a base model.
Come on!! No one knows what im talking about???
Old Jun 1, 2006 | 08:54 PM
BB6racer's Avatar
raise the car up and set the car on jackstands. use the jack to compress the suspension. check if you are bottoming out the shock. if you are bottoming out the shock, then try cutting the bump stop, or replacing the shock with aftermarket, shorter shocks. if you are not bottoming out he shock then you might be able to but the spring.
on another note, you car will not handle very good without aftermarket shocks. you will bounce worse than pam's ***** on baywatch. and i have about 0.5" - 1.0" gap between my fenders and tires and i bottom out a lot, so you will bottom out on a tic-tac.
Old Jun 2, 2006 | 02:49 AM
bb4socal's Avatar
yeah that was gonna be the next thing to check...Thansk guys. ill be trying to work this out.
Old Jun 2, 2006 | 09:00 AM
darkspector's Avatar
get a full coilover kit and call it done... or get new shocks with with shorter than stock body length
Old Jun 2, 2006 | 09:56 AM
Shakes's Avatar
space cadet
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itsdatdncguysal &raquo;</TD></TR><TR><TD CLASS="quote">is your friends 5th gen and sh?if so i was told you cant lower them as much as the base.</TD></TR></TABLE>
Thats your issue right there. You are spouting off crap that others told you. Speak from experiance or don't speak at all.
to the OP,
You need to find out some things, how long are the coils, what is the spring rate, are they installed correctly (i.e. are the top hats set up right. some have you take out the rubber inside, some have you add some, etc).
Old Jun 2, 2006 | 12:35 PM
OneLude2envy's Avatar
Default Re: (darkspector)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by darkspector &raquo;</TD></TR><TR><TD CLASS="quote">get a full coilover kit and call it done... or get new shocks with with shorter than stock body length</TD></TR></TABLE>
like he said just get some real coilovers and call it a day....
if u need some i got some great prices of TEIN, BUDDY CLUB, Tanabe and some others that i can't seem to think of right now
94teggyls
Mar 18, 2003 11:08 PM
ViEtBoY9o9
Jan 2, 2003 12:38 PM
ochdog
Aug 9, 2002 12:05 PM
