shaking vibration while breaking
Old Jun 1, 2006 | 04:28 PM
extensioncordy's Avatar
Default shaking vibration while breaking
i changed my brakes and rotors because i was told i had warped rotors because when i stop my steering wheel shakes and the car shakes kinda. but i put new brakes on and there is no change. any idea on what this is?
91 hatch
Old Jun 1, 2006 | 04:30 PM
.Manny.'s Avatar
Touching My Member
Default Re: shaking vibration while breaking (extensioncordy)
i have the same problem, i was told it was the tie rod bushings.
I'm saving to change out all the bushings.
to shaking, gets a lil scary sometimes.
Old Jun 1, 2006 | 04:31 PM
Tyson's Avatar
check your tie rods and steering rack end bushing.
Old Jun 2, 2006 | 04:59 AM
crx_88_si's Avatar
Default Re: shaking vibration while breaking (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">check your tie rods and steering rack end bushing.</TD></TR></TABLE>
Old Jun 2, 2006 | 08:56 AM
ragingti's Avatar
Default Re: shaking vibration while breaking (crx_88_si)
Could also a bent hub(the part the rotor sits on). Also, pull the rotor off and check the face of the hub. If there is alot of rust on the hub the rotor won't sit flush with the hub and that will cause a shake. Good chance it's a tie rod though.
miked198729
Aug 17, 2013 06:38 AM
mikecp
Jul 3, 2010 11:03 PM
the_dxB16
Jul 30, 2009 07:33 PM
95BoostedEJ1
18
Jan 1, 2009 07:52 AM
rscawley
Aug 6, 2002 10:12 AM
