ECU???????
Old Jun 1, 2006 | 12:41 PM
The7169's Avatar
Default ECU???????
What is the stock ECU in a 2001 lude? Does the ECU have to be reset if it is removed from a wrecked car( car still ran perfect after wreck)? Thank you to anyone that can help.
Old Jun 1, 2006 | 02:24 PM
petern101's Avatar
Default Re: ECU??????? (The7169)
stock is a p13. the ecu will reset with no power in a wrecked car.
Old Jun 1, 2006 | 02:48 PM
98vtec's Avatar
moderator emeritus
Default Re: ECU??????? (petern101)
p13 is OBDI 92-95
p5m is OBDII 97-01
Old Jun 2, 2006 | 10:57 AM
The7169's Avatar
Default Re: ECU??????? (98vtec)
Thank you for your help. But do I need to physcaily reset the ECU or will it reset itself?
Old Jun 2, 2006 | 03:56 PM
homesauce's Avatar
If you removed it from a car, then it probably will reset itself.
Old Jun 4, 2006 | 08:31 AM
The7169's Avatar
Default Re: ECU??????? (homesauce)
Thats what I was thinking (hopeing) also.
SOHC_MShue
Oct 14, 2002 11:22 AM
