Pin-Lock for crank pulley...Reusable??
Old Jun 1, 2006 | 11:10 AM
Adern's Avatar
Default Pin-Lock for crank pulley...Reusable??
88' Integra RS DOHC 5speed...d16-a6
I found another crank pulley bolt & washer. I need the "woodruff" key...How can I remove one from a vehicle at the junkyard??...Just the pin/key.
I need this car running asap...No time or money to go dealer!!!
Thanks guys.
-Adern
Old Jun 1, 2006 | 11:13 AM
DC2 Mang's Avatar
Default Re: Pin-Lock for crank pulley...Reusable?? (Adern)
you can remove one and re-use it
i re-use them all the time unless they are damaged
Old Jun 1, 2006 | 11:18 AM
LL2009's Avatar
Default Re: Pin-Lock for crank pulley...Reusable?? (DC2 Mang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2 Mang &raquo;</TD></TR><TR><TD CLASS="quote">you can remove one and re-use it
i re-use them all the time unless they are damaged</TD></TR></TABLE>
Old Jun 1, 2006 | 11:21 AM
Adern's Avatar
I see...I lost the original. What's the best way to remove the pin without messin it up?
Thanks for the quick reply.
-Adern
Old Jun 1, 2006 | 11:50 AM
DC2 Mang's Avatar
Default Re: (Adern)
take another pulley off slowly and look to see where it is, it should be on the pulley, or the crank, or somewhere close by on the ground
Old Jun 1, 2006 | 02:20 PM
Adern's Avatar
Default Re: (DC2 Mang)
Problem Fixed!!!!!!!!!!!...She's purrin' like a cat now!
Thanks for the help guys!
-Adern
bseriescrxsi
Mar 31, 2008 12:11 PM
DC4 Rasta
Aug 27, 2007 12:50 PM
rplopes
Mar 10, 2006 05:13 PM
Adam.
Jul 28, 2005 07:35 AM
fe519
May 13, 2005 07:19 AM
