Low oil pressure.....Won't engage Vtec...????? Please help!!!!!
Old Jun 1, 2006 | 09:37 AM
WhiteLightening's Avatar
Default Low oil pressure.....Won't engage Vtec...????? Please help!!!!!
Hey guys, I just got my bottom end rebuilt on my B17A1. The only thing changed was pistons, main bearings, and the oil pump was swithced to a type R (p73) oil pump.
I put about 20 miles on the motor before the first time I rolled into vtec and it engaged but i didn't hold it on. I tired it again and the motor detonatied only once.
Now since then I have low oil pressure and can only engage vtec when its cold and getting worse.
I tried using a thicker oil and didn't help at all.
Any suggestions.........I want to say oil pump but its brand new.....and one of the only other things is if the main bearings were set on the loose side and robbing all my oil pressure.
My oil pressure dosn't go above 35psi on w.o.t. and about 25psi part throttle.
Any suggestions are greatly appreciated!!
- Is the type r oil pump compatible with the B17A?
Old Jun 1, 2006 | 10:05 AM
Default Re: Low oil pressure.....Won't engage Vtec...????? Please help!!!!! (WhiteLightening)
Also there are no engine codes, lights, no notification of problems electroniclly.
I have Hondata S200 and during tuning it even switches to the vtec map, but mechanically vtec won't engauge.......
Old Jun 1, 2006 | 10:46 AM
BOOSTED RIVAL's Avatar
Wow that a low oil pressure. How built the motor for you. If the bearing clearance is not right that what happen. The oil pressure should be 70 psi to 85 psi for a type R oil pump. My is at 75psi wot and 25psi idle.
ari integra
Sep 22, 2024 12:37 PM
tunerkid07
Aug 13, 2007 02:42 PM
Vtecme92
Jul 10, 2006 06:27 PM
WhiteLightening
Jun 1, 2006 10:20 AM
91integraLSVTEC
Sep 14, 2003 02:33 AM
