95lx ... hit a tire ... estimate legit?
Old Jun 1, 2006 | 07:53 AM
fleetmack's Avatar
Default 95lx ... hit a tire ... estimate legit?
I was driving home from work yesterday when (long story short) I ran over a tire. It sounded viscious when it hit the underside of my car, and there was a horrible vibrating noise when I accelerated. That seems to have fixed itself (not positive of that) but I went in to have it checked out ... here is a copy of my estimate:
http://www.fleetmack.com/image...e.jpg
Old Jun 1, 2006 | 08:59 AM
lunarone's Avatar
Default Re: 95lx ... hit a tire ... estimate legit? (fleetmack)
this mechanic is looking for some gravy and he is trying to get it from you.
Old Jun 1, 2006 | 09:10 AM
snyderman5's Avatar
definately do no have him fix your car
Old Jun 1, 2006 | 09:18 AM
fleetmack's Avatar
Default Re: 95lx ... hit a tire ... estimate legit? (snyderman5)
they're telling me that the brake master ( i have no idea what that is ) is an absolute must fix as it's leaking fluid or something or another. they said the rest isn't absolutely necessary, but my exhaust and alignment is all jacked up and my tires will go bald very fast as a result of this ....
shed some light on the brake master for me?
Old Jun 1, 2006 | 09:31 AM
sj993's Avatar
The brake master cylinder?
Old Jun 1, 2006 | 09:34 AM
mattf22b1's Avatar
i don't see how your brake master cylinder could have got damaged from your description. this is what it looks like and you should be able to find it on the top right of your engine bay, if you have your car do the brakes work properly
Old Jun 1, 2006 | 11:09 AM
RiceRocketDave's Avatar
Default Re: 95lx ... hit a tire ... estimate legit? (mattf22b1)
It was most likely leaking before this happened and the shop did an inspection of the whole car and found it.
If you hit the tire hard enough, all this sounds reasonable. Since you know what all is wrong why not go buy the parts and do the install yourself. None of it is hard to do.
Old Jun 1, 2006 | 03:32 PM
HONCORD's Avatar
Default Re: 95lx ... hit a tire ... estimate legit? (RiceRocketDave)
Ya, thats a rip off. Master cylinder? Unless you busted your brake line and ran it dry for a long time.
Old Jun 1, 2006 | 05:27 PM
YeuEmMaiMai's Avatar
that is reasonable. The MC was most likely bad and they are just telling him about it.
Old Jun 2, 2006 | 09:15 AM
Superorb's Avatar
I don't see how running over a tire would warrant needing a new front crossmember, or both lower control arms and shocks. The prices are cheap actually for the parts, but they shouldn't be needed. I would take it to the alignment place and they can tell you how far out of alignment it is. But, if it drove fine before and now pulls, than you very well could have bent some parts. Was it a semi tire you hit going like 75mph?
Old Oct 27, 2006 | 12:43 PM
fleetmack's Avatar
Default Re: (Superorb)
sorry guys ... i'm just looking through my old posts today and trying to clean them up for any future people searching for solutions ...
the master brake cylinder was something he just saw while doing the inspection (and i did need it replaced, which I did)
I went ahead and got it re-aligned at an alignment shop for $80 ... the guy said he fixed about "70% of the problems" and told me it'd do, but if I were keeping the car for another 200K miles it's something I should fix (I'm only keeping it until 250K, up to 211K) so I'm not that concerned if I have to buy some new tires before I get to 250K.
Also, yes, this was a shredded semi tire that I hit, curled up like a elongated U. The midpipe of my exhaust was hitting my firewall (or whatever it's called) and they had to bang that out as I was getting some wicked vibration that was loud as hell.
ohboitony
Oct 21, 2008 05:33 PM
LIVE 2 DRAG
Feb 6, 2006 06:27 PM
Mandeep
Aug 17, 2005 06:23 PM
Jinya1004
13
Jul 3, 2004 01:48 PM
hondamama
Mar 9, 2004 08:34 PM
