96 spec vs 98 spec jdm itr - differences in track?
Old Jun 1, 2006 | 06:56 AM
YumVTEC's Avatar
Default 96 spec vs 98 spec jdm itr - differences in track?
I found this data in another post:
GSR:
Front Track: 1475 mm / 58.1 in
Rear Track: 1470 mm /57.8 in
USDM ITR:
Front Track 1480 mm / 58.3 in
Rear Track 1475 mm / 58.1 in
We all know the USDM ITR has a slightly wider track than other Integras and thus uses higher offset factory rims compared to other Integras. I imagine the same holds true for the 98+ spec JDM ITR as it is also 5-lug, and the only difference from USDM is 36mm front axles.
Here is my question, for the 96-97 JDM ITR's that are 4x114.3 that have the same calipers and same diameter rotors as any 94-01 USDM Integra (non-ITR), is the track the same as a non-ITR Integra, or is it wider like all USDM ITR's and 98+ Spec JDM ITR's?
I couldn't find a thread where this had been discussed previously. If I am mistaken please point me in the right direction.
I am asking this because I just picked up a set of 16x7 +33 TE37's in 4x114.3 for my 97 JDM ITR. I'm about to order tires, and I don't want to have any rubbing issues when I do lower the car. I don't know if I should stay safe and go 205/45/16 or if I could go 215/45/16 or even 225/45/16. I don't know the track of the JDM ITR, and I know that a +33 offset on a 7" wide wheel isn't crazy, but just want to make 100% sure.
Thanks for your input.
Old Jun 1, 2006 | 07:41 AM
mugenracer's Avatar
96spec JDM ITRs have the same rear track as all non typeR JDM Integras so i'm guessing that its also the same as US non TypeR integras also.
Old Jun 1, 2006 | 07:55 AM
YumVTEC's Avatar
Default Re: (mugenracer)
you're 100% sure on that then? if that's the case then the front track is probably the same also.
team top secret
Nov 28, 2010 03:30 PM
jamison1486
Sep 9, 2010 11:53 PM
ITR1148
Jul 2, 2007 07:24 PM
scooter
Aug 26, 2004 04:15 PM
kenji
Nov 19, 2002 02:34 AM
