Type R Rear Sway bar on an LS
Old Jun 1, 2006 | 04:15 AM
MeekalLS's Avatar
Default Type R Rear Sway bar on an LS
Read somewhere that the Type R rear sway bar put on an LS causes alot of oversteer, Searched but I cant find anything on this. Does anyone know if this is true or not or if there is any advantage to having this setup?
Old Jun 1, 2006 | 04:30 AM
nautica_t's Avatar
i don't know about oversteer or not, but if you do plan on getting an ITR swaybar, your going to have to get a re-enforcement kit otherwise you'll tear out your lower subframe.
Old Jun 1, 2006 | 06:36 AM
infulleffect's Avatar
Default Re: (nautica_t)
The stock ITR sway bar will not bolt up to the LS subframe...you would either need to purchase a rear crossmember brace or purchase the ITR rear crossmember pieces
Old Jun 1, 2006 | 06:38 AM
94rs-turbo's Avatar
well it will bolt with some spacers and flat plates but best to buy the kit but it feels great when u put it in
Old Jun 1, 2006 | 06:42 AM
Tim2179's Avatar
eight equals equals equals D
Community Builder
Loved
Default Re: (infulleffect)
Wow, so much misinformation. I've had the ITR rear sway bar on my LS for over a year. No it does not cause excessive oversteer. And my subframe is still intact. You need to order a BSQ kir which is basically a spacer, to make it fit: http://www.geocities.com/bretq/?20061
Old Jun 1, 2006 | 06:47 AM
94rs-turbo's Avatar
Default Re: (Tim2179)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tim2179 &raquo;</TD></TR><TR><TD CLASS="quote">Wow, so much misinformation. I've had the ITR rear sway bar on my LS for over a year. No it does not cause excessive oversteer. And my subframe is still intact. You need to order a BSQ kir which is basically a spacer, to make it fit: http://www.geocities.com/bretq/?20061</TD></TR></TABLE> thank you!
Old Jun 1, 2006 | 08:07 AM
ThePro's Avatar
I've also had the ITR swaybar on my LS for awhile. It all depends on your spring setup for oversteer. If you are autocross racing it tends to give you some (not OMGWTFBISCUIT) oversteer and on throttle lift off (in a turn and let go of the throttle quickly) it can, under the right circumstances, cause the rear end to break free.
But it improves handling a whole bunch. One of the best bang for your buck handling modifications you can put on your car.
As for the spacer kit. It's not so much a spacer kit as it is a subframe reinforcement kit. Check out this thread, which was posted just a few days ago, about subframe tearout from larger rear sway bars.
Old Jun 1, 2006 | 08:53 AM
00IntegrAllmotoR's Avatar
HT Black OPs
Default Re: (ThePro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by infulleffect &raquo;</TD></TR><TR><TD CLASS="quote">The stock ITR sway bar will not bolt up to the LS subframe...you would either need to purchase a rear crossmember brace or purchase the ITR rear crossmember pieces </TD></TR></TABLE>
I'm glad someone corrected the misinformation.
Also there's a nice DIY write up on team-integra or you could pm me and I can talk you through it. Like said above you will need some type of mounting kit. (beaks, BSQ, ASR ect..) I have the 23mm ITR and the Beaks and love it. Great handling, but I also have other mods to aid as well. Dont forget to get some new bushings.
ICBmotorsports sells a nice kit that includeds everything you will need, but you could always shop around and find it for cheaper. GL
Old Jun 1, 2006 | 08:54 AM
mrdeadman's Avatar
They let me pick
Default Re: Type R Rear Sway bar on an LS (MeekalLS)
my tires are so worn to hell i can get the back end out easily, and with a little agressive driving, I pulled a four wheel slide yesterday, seriously.
here's my love:
Old Jun 1, 2006 | 09:18 AM
HT Black OPs
Default Re: Type R Rear Sway bar on an LS (mrdeadman)
You can also upgrade the bolts to Grade 8 to be a little safer from the sub-frame tear-outs.
Old Jun 2, 2006 | 04:16 AM
MeekalLS's Avatar
Alright Thanks for the help guys!
Old Jun 2, 2006 | 06:49 AM
rockdude14's Avatar
Default Re: Type R Rear Sway bar on an LS (00IntegrAllmotoR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00IntegrAllmotoR &raquo;</TD></TR><TR><TD CLASS="quote">You can also upgrade the bolts to Grade 8 to be a little safer from the sub-frame tear-outs.</TD></TR></TABLE>
grade 8 bolts wont do anything
subframe tearout is where the subframe breaks not the bolts
go with either beaks or bsq kit
if you want somthing bigger
asr brace
or comptech
Old Jun 2, 2006 | 07:31 AM
RaceMyGhost's Avatar
Default Re: Type R Rear Sway bar on an LS (rockdude14)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rockdude14 &raquo;</TD></TR><TR><TD CLASS="quote">
asr brace
or comptech</TD></TR></TABLE>
X2 ASR brace
Old Jun 2, 2006 | 07:54 AM
Alexander's Avatar
You are referring to the stock ITR rear lower tie bar. The sway bar is a direct bolt-on, however you MUST use either the Beaks kit or the BSQ kit as to reduce the chances of sub-frame tearout since non-ITR's do not have a reinforced subframe stock.
Old Jun 2, 2006 | 08:09 AM
Fat Chick Magnet's Avatar
dont all integras oversteer either if they have strut bar or not?
Old Jun 2, 2006 | 11:11 AM
Alexander's Avatar
Default Re: (dc2rtek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2rtek &raquo;</TD></TR><TR><TD CLASS="quote">dont all integras oversteer either if they have strut bar or not?</TD></TR></TABLE>
Integras are usually prone to understeer. We are not discussing strut bars either, this is about Sway bars.
Old Jun 2, 2006 | 11:14 AM
motoman's Avatar
My experience is that if you put just the swaybar on, and do nothing else, it will be more prone to sudden and uncontrollable oversteer only if you do heavy trail braking into a corner, or with abrupt throttle lift in a corner. If you also put the ITR struts and springs on, then it becomes predictable again, only with a much higher limit. I would get used ITR struts and springs (and you will also need the ITR lca no matter what if you are going to put the ITR swaybar on) if I was putting on the sway bar. I got mine from http://www.jdmtheory.com for a really good price.
Old Jun 2, 2006 | 11:29 AM
Tim2179's Avatar
Community Builder
Loved
Default Re: Type R Rear Sway bar on an LS (motoman)
You don't need ITR LCAs with the ITR sway bar.
You do need ITR LCAs if you get ITR struts though.
Old Jun 2, 2006 | 11:53 AM
motoman's Avatar
Default Re: Type R Rear Sway bar on an LS (Tim2179)
Really? I thought if you put the sway bar on with the original lca, the little link thing that connects the sway bar to the lca will sit at an odd angle.
Old Jun 2, 2006 | 12:29 PM
Leo C's Avatar
Night Owl
you will needs a beaks/bsq kit.
as far as subframe tearing goes, isn;t that more common with EK owners than DC4 owners? never heard of it happening w/ a LS.
freshCROOKS
Aug 12, 2014 05:46 AM
Jdmls
Jun 8, 2007 11:57 AM
lubmyinteg
Suspension & Brakes
Apr 29, 2007 11:35 PM
integranator
16
Nov 24, 2002 08:44 PM
jmlmr2
Sep 17, 2001 12:20 PM
