timing belt woes
ok just finished head gasket change b16a
timing belt broke pulled head to inspect valves
new everything ok put crank straight up on the oil pump gear and cam gears straight up put belt on rotate clock wise three teeth counter clockwise
ok thats where the prob is once i get the timing cover on and put the pulley on the cams are straight up but the pulley is not on the white mark its a stock pulley on brand new timing covers and the head nor the block has been decked
any help would help im all cracked out been working since 5pm and its 2:35 now lol
the beast lives again
lol i forgot about the two little notches in the cam gears and i was trying to eye the straight up on the cam caps
thanks EE_Chris
and I had the tps and map switched fixed fired right up set timing and drove great I <3 My honda
thanks EE_Chris
