installing foglights into my 96 ek
what trouble is that? wrong section of the forum buddy... but any ways take the bumper off and cut out the cutouts.. u can usually tell where to cut... wiring was easy for me... simple...
The brown plugs should be labeled on them or in the installation manual (depending if you got OEM or Depo). Then match up the numbers to the numbers on the accessory slots of your fusebox.
I put them on my 97 and I had to get the wiring harness that is in the bumper that connects the lights to the brown plugs in the engine compartment, then you'll need the fog light switch and the wiring harness that connects the headlight switch to the relay and the fog light switch and also you'll need to get the relay for it to work correctly. I found that the horn relay works so I used that and left the horn disconnected and I finally ordered one so I could finish it off properly with everything working.
