Help car wont start or crank
Old May 31, 2006 | 09:02 PM
shorbie621's Avatar
Default Help car wont start or crank
1992 honda civic
let see i looked around.. but i didn't find anything sorry..
The car only starts after it is push started..
I try to jump start the car....but still doesnt work
what does the fellow honda techers think the problem is?
Old May 31, 2006 | 09:05 PM
John M's Avatar
Default Re: Help car wont start or crank (shorbie621)
starter?
Old May 31, 2006 | 09:08 PM
shorbie621's Avatar
Default Re: Help car wont start or crank (lowryder227)
how so?
Old May 31, 2006 | 10:16 PM
sol2hatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shorbie621 &raquo;</TD></TR><TR><TD CLASS="quote">how so?</TD></TR></TABLE>
If your starter is bad, then it wont crank the engine, and your car will not start. damn i am a genius, lol
Old Jun 1, 2006 | 10:19 AM
shorbie621's Avatar
Default Re: Help car wont start or crank (sol2hatch)
hehehe still need help
Old Jun 1, 2006 | 10:24 AM
1baddcivicsi's Avatar
On early hondas like my 92 accord the distributor goes out alot. I would check your car to see if its getting any juice. @ any auto parts store they are usually $160+ but u get a free lifetime warranty. I would seriously check your distributor!!
Old Jun 1, 2006 | 10:36 AM
instructor74's Avatar
Default Re: Help car wont start or crank (1baddcivicsi)
if he can bump start it its not going to be the distributor.It sounds like a starter or maybe a bad ign. switch. Give us more info if you want more help. What have you checked?
Old Jun 1, 2006 | 10:57 AM
flogo2003's Avatar
I dont kno whats wrong with your car, but I have a d16z6 Head with stage 1 Cam and adjustable Cam Gear for sale (needs Valve Cover Bolts) GL with your car bro.
I'd PM you but it like wont let me for some reason.
Modified by flogo2003 at 12:19 PM 6/1/2006
Old Jun 1, 2006 | 11:10 AM
shorbie621's Avatar
Default Re: Help car wont start or crank (flogo2003)
Pretty much i tried to start it and it wont work and when i push started it works? im guessing its the battery ima going ot go check it out today. i checked all the grounds and stuff and its all good. iono what else to say? if theres a specific thing u want to know let me know. THANX FOR THE HELP SO FAR
Old Jun 1, 2006 | 11:18 AM
EH339's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shorbie621 &raquo;</TD></TR><TR><TD CLASS="quote">hehehe still need help</TD></TR></TABLE>
So have you checked to see if your starter is bad? I would go with your starter as your car is a 92. Honda starters are good for a healthy ten-eleven years, after that when they die, it's never any surprise to me.
Also make a visual inspection of your main relay box to see if the solder on the pins is cracked.
Old Jun 1, 2006 | 11:54 AM
EK 2 9K's Avatar
check the ground wire that goes to the starter make sure the connection is good and clean i just recently had this problem over the weekend i had power to everything but no start or crank....pop started for a day or 2 and just took the ground off cleaned up the connection and she started rite up
Old Jun 1, 2006 | 12:22 PM
shorbie621's Avatar
Default Re: Help car wont start or crank (96JDMEK)
still checking up on it.. i went to pep boys and got a new battery.. but still same stuff im guessing its the starter now?
Old Jun 1, 2006 | 12:25 PM
spoonracer84eg's Avatar
Look what happens... You didnt listen and waisted money on a battery. Check the starter!
Old Jun 1, 2006 | 12:56 PM
shorbie621's Avatar
Default Re: Help car wont start or crank (spoonracer84eg)
well i didnt really waste $$ the battery was dieing out anyways... soo ill just check the starter now..
Old Jun 1, 2006 | 01:06 PM
-Gary-'s Avatar
Starter = Easy
Old Jun 1, 2006 | 01:35 PM
shorbie621's Avatar
Default Re: Help car wont start or crank (scuzz)
okay thanx i just need a starter n ow
Old Jun 1, 2006 | 01:57 PM
shorbie621's Avatar
my friend told me the it cant be the starter because the car started when we push started.. so anyone else has any idea?
Old Jun 1, 2006 | 02:26 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shorbie621 &raquo;</TD></TR><TR><TD CLASS="quote">my friend told me the it cant be the starter because the car started when we push started.. so anyone else has any idea?</TD></TR></TABLE>
Your friend is an idiot.
Remove the starter from the car and have it tested. Does the starter solenoid click? Are you getting 12v at the starter?
Old Jun 1, 2006 | 02:42 PM
shorbie621's Avatar
Default Re: Help car wont start or crank (Targa250R)
okay okay ill go cehck on on the starter
Old Jun 1, 2006 | 05:19 PM
ht834's Avatar
If the starter just clicks when your trying to start it or even dosent click try hitting with a hammer. Yeah I know it sounds crude but it works. Does the car turn over but not start? If so it could be your coil in the dist. Or the Ignitor. The coil isnt uncommon for going bad.
Old Jun 1, 2006 | 05:57 PM
shorbie621's Avatar
Default Re: (ht834)
no it doesnt crank probably the starter ill invest in one tommrow thanx for helping me sofar guys i checked up whatever u guys trew at me alredy
Old Jun 1, 2006 | 06:52 PM
EH339's Avatar
Default Re: (shorbie621)
The main relay is under the dash on the far lefthand side of the car. You have to open up the main relay box. A bright light and a magnifying glass will help. Just check for cracks in the solder around all of the pins. Between the age of the car and vibrations from driving, the solder gets tired and cracks develop.
If YOU do a search for "Honda main relay repair" on this board or Google, you should be able to find enough info about these.
Old Jun 1, 2006 | 06:53 PM
EH339's Avatar
And main relays look like this:
Old Jun 1, 2006 | 07:39 PM
Default Re: (EH339)
With the main relay uplugged the starter will still work. So that isnt it. Probably the starter if nothing happens when you turn the key.
Old Jun 1, 2006 | 08:05 PM
DohcSide's Avatar
Default Re: (spoonracer84eg)
yeah pretty much i think is the starter did you check ever single grond ?
