obd1 p72 info neded (searched and looked through the FAQ)
Old May 31, 2006 | 07:44 PM
Kelly.'s Avatar
I've quit using this account
Default obd1 p72 info neded (searched and looked through the FAQ)
i am tryin to get info on a p72 that i just picked up.
i am told it is a obd1 p72, but it is alot smaller then my current p28.
the numbers on the side are:
37820-p72-q01-810-100234
i searched the teg forum and read through the FAQ but didnt see anything with complete ecu codes in it.
only thing i could find was this:
https://honda-tech.com/zerothread?id=1500905
which tells me it is a jdm ecu, but doesnt say obd1 or not
i dont know enough about it to say for sure.
any help would be great
thanks in advance
Old May 31, 2006 | 08:07 PM
lVlemphizStylez's Avatar
Default Re: obd1 p72 info neded (Kelly.)
you can tell obd by the style of the plugs to the ecu...
http://technet.ff-squad.com/wiring.obd1.htm (OBD1 ecu plugs)
http://www.hondaswap.com/forum...id=28 (OBD2)
Old May 31, 2006 | 08:52 PM
Kelly.'s Avatar
Default Re: obd1 p72 info neded (lVlemphizStylez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lVlemphizStylez &raquo;</TD></TR><TR><TD CLASS="quote">you can tell obd by the style of the plugs to the ecu...
yep, mine is obd1
Old May 31, 2006 | 09:59 PM
iH8RICERZ's Avatar
yup..if your ecu is smaller than the p28, then it is a jdm ecu. But I've never heard of the code ending with a Q01... I've seen A01, L01, C01, G01, but never Q.....interesting
Old Jun 1, 2006 | 11:50 AM
Kelly.'s Avatar
i can get pics if you need
as long as it works, its all good.
just wanted to make sure i knew what i was getting into.
from what i have read the jdm ecus are alittle harder to chip then the usdm ones
Jap_Spec_Imports
Aug 10, 2009 07:14 PM
808jdm_profileEG6
Apr 28, 2009 01:33 PM
egpwns
Mar 18, 2007 11:59 AM
b18c4door
Oct 24, 2003 06:56 AM
