96 HX with 1.6 engine
Old May 31, 2006 | 05:57 PM
deuskid's Avatar
Default 96 HX with 1.6 engine
I'm going to be buying this used from a neighbor. In about 15k miles I'm going to need to do the timing belt [it'll be at 200k].
I've done a search and didn't find exactly what I was looking for.
I'd like recommendations/links to a DIY complete Tbelt, water pump, tensioner etc job.
Also, is there a 'better' manual for me to buy?
thanks,
John
Old May 31, 2006 | 06:17 PM
Syndacate's Avatar
there are links all over ebay for DIY timin belt changes, here, give me 10 seconds, let me search for one....
https://honda-tech.com/zerothread?id=649277
Damn, think it took me 13 seconds, oh well, there ya go, it's not hard ft in any matter, but never-the-less, u should change ur timing belt at 180 (every 90) to be on the safe side.....but if u do it every 100 whatever, power to ya
Old Jun 1, 2006 | 02:57 PM
deuskid's Avatar
Default Re: (Syndacate)
I have no idea how ebay is related to the link you provided. I don't have the Civic yet so don't know if a 93 Del Sol has the same engine as a 06 HX but if it does then your link will be a big help - thanks.
My second question is: is there a 'better'/perferred repair manual?
also, I won't get this car until next week what models/years have the same engine as a 96 HX?
thanks
John
Old Jun 1, 2006 | 02:59 PM
t0p_sh0tta's Avatar
Default Re: (deuskid)
96-00 Hx share the same motors.
Get the factory service manual at HelmInc.com.
Old Jun 2, 2006 | 03:18 AM
deuskid's Avatar
Default Re: (t0p_sh0tta)
thanks Top Shotta....
if there are any other threads or on line resources I'd appreciate someone pointing me toward them.
John
Old Jun 2, 2006 | 05:52 AM
pumatec8's Avatar
Default Re: 96 HX with 1.6 engine (deuskid)
if you dont have an impact wrench, be prepared to head to a shop or a friends place to get the crank pulley off...it's a bitch.
if you are going to do any car repair, it is necesssary to have a manual, and hard copy is the way to go. dont worry about getting an online thread or resource because the helms is all you need.
Old Jun 2, 2006 | 08:39 AM
specv5150's Avatar
Default Re: 96 HX with 1.6 engine (pumatec8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pumatec8 &raquo;</TD></TR><TR><TD CLASS="quote">if you dont have an impact wrench, be prepared to head to a shop or a friends place to get the crank pulley off...it's a bitch.
if you are going to do any car repair, it is necesssary to have a manual, and hard copy is the way to go. dont worry about getting an online thread or resource because the helms is all you need. </TD></TR></TABLE>
I can speak from expereince. I ended up taking my car to Honda becuae that bolt was such a PITA!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">there are links all over ebay for DIY timin belt changes, here, give me 10 seconds, let me search for one....
Damn, think it took me 13 seconds, oh well, there ya go, it's not hard ft in any matter, but never-the-less, u should change ur timing belt at 180 (every 90) to be on the safe side.....but if u do it every 100 whatever, power to ya</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deuskid &raquo;</TD></TR><TR><TD CLASS="quote">I have no idea how ebay is related to the link you provided. I don't have the Civic yet so don't know if a 93 Del Sol has the same engine as a 06 HX but if it does then your link will be a big help - thanks.
thanks
John</TD></TR></TABLE>
That link should help you tremendously. While the Z6 and Y5 are different engines at heart, they are basically the same for what you are trying to do. Everything is in the same spot. I did not get to finish doing it myself since that bolt is a bitch, but I did basically everything in that write up (I used a helms). So you can use that but a manual will help for this and other things unless you have a laptop and have access to it while workign on your car. Even a cheap Chiltons or hanyes will work better than nothing.
Old Jun 7, 2006 | 04:08 AM
deuskid's Avatar
Default Re: 96 HX with 1.6 engine (specv5150)
Thanks all for your help.
I pick up the car this weekend. I need to find out what engine designation it has [I'm hoping the owner still has the owners manual].
Looks like I need to find a Helm's manual.
John
Old Jun 7, 2006 | 07:05 AM
specv5150's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deuskid &raquo;</TD></TR><TR><TD CLASS="quote">Thanks all for your help.
If it is an HX, it will have the D16Y5.
Old Jun 7, 2006 | 07:15 AM
axtran's Avatar
lol Syndacate tryin' to be a smartass and accidently types in Ebay. hahaha
Old Jun 7, 2006 | 02:13 PM
deuskid's Avatar
SpecV....
what is a D16YS?
also, anyone...
what is the engine designation... is it a H22 or what?
thanks,
John
Old Jun 7, 2006 | 03:38 PM
pumatec8's Avatar
he told you that it is a d16y5. the letter and number after the "16" help to let you know what form of the single overhead cam engine you have. the "d16y5" is the engine found in the civic hx.
biker9075
11
Jan 23, 2009 08:11 AM
Camvill
Jan 11, 2008 11:39 PM
nivlacs3z
May 7, 2007 10:15 AM
mikester_91
Apr 6, 2007 11:21 PM
