Suspension upgrade is complete! :)
Old Apr 14, 2002 | 03:52 PM
SlyGSR's Avatar
Default Suspension upgrade is complete! :)
Finally, my baby is no longer stock..went from GSR w/AEM to:
Toyo T1-S, AGX KYB, H&R OE, Rear Sway Bar, xdrilled rotors and axxis metal master pads
What a difference! the car is quite a bit tighter on curves now
but I must say that the T1-S's Rock! last night it was raining cats and dogs but the car handle and gripped as if I was driving on dry pavement...holy $hit!
Question: when adjusting the agx shocks (mine are adjusted from the top), there is a small white dot beside the screwslot...when the white dot points towards a number (I have 1 to 4), does that mean that its set at that number or do I use the screw slot position to tell where's it set at?
If anybody has pics on top-adjusted agx shocks that would be great.
TIA
SlyGSR
Old Apr 14, 2002 | 04:47 PM
neo1z's Avatar
Default Re: Suspension upgrade is complete! :) (SlyGSR)
the white dot is what number you are on
Old Apr 14, 2002 | 04:58 PM
Calavera's Avatar
Default Re: Suspension upgrade is complete! :) (neo1z)
Remember, when you're adjusting it with the screw driver, push it in first, then rotate.
And yeah, the white number indicates what stiffness you're on.
Old Apr 14, 2002 | 05:05 PM
JM Performance's Avatar
Default Re: Suspension upgrade is complete! :) (Calavera)
how do you like the springs? low enough? thats the setup i thought of getting.
Old Apr 14, 2002 | 05:09 PM
SlyGSR's Avatar
Default Re: Suspension upgrade is complete! :) (00SilverLS)
Thanks guys,
I like the drop. its good enough to reduce/eliminate the ugly fender gap that was there before. Its only a 1" drop but its makes a marked difference from stock.
Old Apr 14, 2002 | 07:25 PM
743power's Avatar
you might want to go to a hardware store and pick up some rubber bolt caps to put on top of the shocks so that the adjustment markings dont get worn off.
Old Apr 14, 2002 | 07:44 PM
FrostyGSR's Avatar
New User
Default Re: Suspension upgrade is complete! :) (743teg)
I have the same setup, as far as the springs and shocks go....I like it alot. The drop is perfect for me, and the stiffness of the suspension is great! I have a lot of fun with it around turns and i don't hear anymore clunks from the old suspension so I'm happy.
Old Apr 14, 2002 | 10:50 PM
SIK IN DA HED's Avatar
New User
Default Re: Suspension upgrade is complete! :) (FrostyGSR)
cool.
Old Apr 15, 2002 | 09:51 AM
SlyGSR's Avatar
"you might want to go to a hardware store and pick up some rubber bolt caps to put on top of the shocks so that the adjustment markings dont get worn off."
You have a good point! thanks!
SlyGSR
92DAB16A
Jan 25, 2012 09:25 PM
ZipTieGUy
Mar 26, 2006 12:36 AM
aandrewcc
Suspension & Brakes
Mar 23, 2006 03:31 PM
stpacura
Feb 2, 2006 08:10 PM
Gizzo
Mar 23, 2005 09:28 PM
