I cant figure it out, Shifting.
Old May 31, 2006 | 05:41 PM
Hanmin's Avatar
Default I cant figure it out, Shifting.
Okay, I sold my acura legend for 2500, i had bought it for 2000 so i am satisfied. I recently purchased a Mitsubishi Eclipse for 5100.
Anyways, i can shift from 1-5 easily, but when i am on a hill i try to shift from N to 1st it stalls, any tips on how to shift it on a hill?
When I am on the hill and I try to shift the car rolls back a little.
Old Jun 1, 2006 | 05:39 AM
Hanmin's Avatar
Bump
Old Jun 1, 2006 | 03:08 PM
thesmogman's Avatar
Default Re: (Hanmin)
I don't know if I should tell you. It's an old chinese secret.
OK, hold the E-brake on until you feel the clutch engage then let off the E-brake.
I feel like your older brother now! It also works in reverse.
Old Jun 1, 2006 | 03:24 PM
ccivic's Avatar
Default Re: I cant figure it out, Shifting. (Hanmin)
Shouldn't be downshifting to first while moving.
Old Jun 1, 2006 | 06:21 PM
Hanmin's Avatar
Ooh thanks smog, well, its a 4 way stop
Thanks
Old Jun 1, 2006 | 07:39 PM
confusatron's Avatar
Default Re: (thesmogman)
That's one way, you can also just practice to where you can rev to 2500 rpm, let off the brake and clutch just right, and go forward smoothly. It's easy once you get timing and pedal pressure down right. I used to have the same problem last year when I first started driving stick too, so don't feel bad. Just practice.
Old Jun 1, 2006 | 11:34 PM
esguerra's Avatar
try to practice getting on the gas instantly after you release the break when on flatland...then you'll be fine on uphills...
Old Jun 2, 2006 | 05:05 PM
Hanmin's Avatar
Thanks guys for all these great advice, but i havent been able to practice because of school, but i plan on practicing this weekend.
Thanks
Old Jun 3, 2006 | 01:37 PM
mehheh1029's Avatar
Is it hard to learn how to drive a stickshift in a short amount of time because I plan on getting a new car in the next few months and I wanted to get a stick and the little experience I do have is driving across a parking lot a couple times and not even getting out of first
Old Jun 3, 2006 | 03:43 PM
Hanmin's Avatar
Well, learning how to do it takes no time at all.
You'll be ok, just dont try double clutching when you first drive, or any other special kinds of things. Just drive so it dont stall and you'll perfect it someday.
ReEducation
Honda Civic (2001 - 2005)
Dec 3, 2015 08:11 PM
turbinedteg7
Jul 13, 2011 08:30 AM
jtshop
Sep 10, 2004 08:46 PM
fishin9975
May 15, 2004 08:46 PM
94GSRNewbie
Aug 4, 2001 11:48 PM
