electrical connectors by oil filter?? help
I'm putting my motor back together, but cannot find where 2 things by the oil filter go.
Where does the one with the prong sticking out of it go, and where does the open electrical connection go that is right next to it?
Modified by homesauce at 2:22 AM 6/1/2006
hard to say but the one prong thing is probly the oil pressure switch.
and the grey plug is for the vacume box under the IM
where does the oil pressure switch go into?
I already plugged a the electrical connector under the IM, there are two of the same connectors from the same wire harness, any more ideas?
Well...that black plug with the prong in the center is the knock sensor. Your is broken. Theres a metal piece that covers that prong. Your **** out of luck... that piece can be 70 dollars or more. I believe the grey one goes to the butterfly vacuum box under the IM.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bb4socal »</TD></TR><TR><TD CLASS="quote">Well...that black plug with the prong in the center is the knock sensor. Your is broken. Theres a metal piece that covers that prong. Your **** out of luck... that piece can be 70 dollars or more. I believe the grey one goes to the butterfly vacuum box under the IM.</TD></TR></TABLE>
The one with the single prong is definitely a broken knock sensor. Mine was broken when I removed my old H23A1 and looked exactly like that.....check to see if there is a plug still in the block (rear of the block towards the top)
avenger63
Apr 6, 2016 10:25 PM
