I NEED A PIC OF A THROW OUT BEARING
My throw out bearing is spinning freely, but i need to make sure how it looks before i buy another one..So if anybody can show me a picture that would help me alot..Thank you
you think so...im just trying to catch peoples eyes by my titles and all im getting is haters...its not that serious...Jeesh.. but i guess im going to have to write all proper now for people wont have titi attacks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tigueremalo »</TD></TR><TR><TD CLASS="quote">IM using a 91 CRX SI tranny on a 92-95 single head vtec</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tigueremalo »</TD></TR><TR><TD CLASS="quote">titi attacks</TD></TR></TABLE>
it should spin. thats how it works.
if it DIDNT spin freely, it would need replacement. it should spin smoothly too, not feel rough.
THANKS TYSON, ITS KARENCITA
But yeah my boyfriend said it spins, but that like it spins while touching the wall...????
its designed to spin with the input shaft independently of pushing the clutch plate to engage and disengage the flywheel.
i dunno, cant really explain it more than that. if its broken, i would think its obvious. they usually just go bad like normal bearings and will start to feel rough as you spin, causing too much heat and then seizing.
it does look a bit different than the one pictured. is it aftermarket? i dunno.
since the tranny is out, its always a good idea to replace it whenever you change the clutch anyway. so just replace it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson »</TD></TR><TR><TD CLASS="quote">
since the tranny is out, its always a good idea to replace it whenever you change the clutch anyway. so just replace it.</TD></TR></TABLE>
i had just replaced mine because it was squeeking really bad for instance my through out bearing i guess overheated and there was a crack on the inside of the bearing that opened up maybe a millimeter once it hit the edge of the bearing if that helps... i just took the two spring things or whatever off got a new bearing and put some high temp grease on,now with my new bearing its alot easier to push the clutch pedal down
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson »</TD></TR><TR><TD CLASS="quote">SNAKES ON A PLANE!</TD></TR></TABLE>
WE GOT SNAKES M*THA F*CKA!
CRX Forum
CRX Forum
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxforum »</TD></TR><TR><TD CLASS="quote">
CRX Forum</TD></TR></TABLE>
Ohhhh I'm so lost. Anyways, how much to they go for at Honda...I should change mine when I do the clutch anyways...just wanting a price range.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv »</TD></TR><TR><TD CLASS="quote">
Ohhhh I'm so lost. </TD></TR></TABLE>
There is a movie coming out with Samuel L Jackson and its called Snakes On A Plane! Here is an artist rendidtion of the possible movie poster.
CRX Forum
CRX Forum
yes anytime you do as much labor as pulling a tranny, you may as well replace all things like these pilot/throwout bearings, the rear-main seal, heck, even the ball joint boots on the knuckle and tie rods.
and after reading yesterdays' Q.U.I.C.K.Q.U.E.S.T.I.O.N. thread, i'm still LOL
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ( o )( o ) »</TD></TR><TR><TD CLASS="quote">yes anytime you do as much labor as pulling a tranny, you may as well replace all things like these pilot/throwout bearings, the rear-main seal, heck, even the ball joint boots on the knuckle and tie rods.
and after reading yesterdays' Q.U.I.C.K.Q.U.E.S.T.I.O.N. thread, i'm still LOL</TD></TR></TABLE>
Haha, your name is boobies.
bc_psychocivic
Sep 8, 2003 03:41 PM
