cracked maifold!!!!!
Im in the process of getting me 96 dx ek hatch smoggged and its throwing a code for a 02 sensor... so i baught the sensor and was going replace it but now i noticed a crack in the stock manifold and pretty sure thats the culprit.
If i cant find a stock one used would a ebay header bolt right in and connect with the stock exhaust piping?
Your typical eBay header isn't CARB legal. Don't forget you're going to need a catalytic convertor, which on the D16Y7 is integrated into the manifold.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheLudeguy »</TD></TR><TR><TD CLASS="quote">searching with no luck.... ok ive located a 99 ex mani local will that work with my little dx motor? sorry for all the questions guys
It will work but you won't have the catalytic converter anymore...you'll fail smog. You need a 96+ DX manifold, or a new manifold + catalytic converter.
As someone else stated, wasn't there a recall for these manifolds cracking? Call the dealer and ask.
</TD></TR></TABLE>It will work but you won't have the catalytic converter anymore...you'll fail smog. You need a 96+ DX manifold, or a new manifold + catalytic converter.
Look in the classifieds here and craigslist. http://www.thepartsbin.com has some oem style ones for sale that are cheaper than from Honda, but they still cost around $300.
http://oem.thepartsbin.com/par...=true
Just try to find a welder that will weld cast. It can be done. Or just fix it yourself. I used a product made by LOC-TITE that is designed for this purpose. It has worked great so far. The fix is about 8-9 months old now.
tbgallant
Dec 16, 2008 08:25 AM
its wraped all the way around the middle im just gonna buy an ebay one.
