rear disc
Old May 31, 2006 | 10:30 AM
ED9man's Avatar
Default rear disc
For people who have done this with an '88 CRX with stamped rear LCA's, do the rear disc trailing arms accept the stamped control arms or do I have to use the cast ones?
Old May 31, 2006 | 11:25 AM
SD_Lurker's Avatar
HT White Ops
Default Re: rear disc (ED9man)
What rear disks are you using?? If your using integra disks they will work fine.
Old May 31, 2006 | 01:14 PM
tmeracz's Avatar
Mine fit all 3 types of LCA just fine: cast Si, cast Std and the 88/JDM stamped style.
I believe they are Integra as well.
Old Jun 5, 2006 | 01:20 PM
ED9man's Avatar
No difference with DA trailing arms and brakes compared to CRX disc ones at all? Is the bushing the bigger one?
Old Jun 5, 2006 | 02:06 PM
Tyson's Avatar
Default Re: (ED9man)
the control arms are completely interchangeable. it doesnt matter if you use 88 or 89-91 for any trailing arm.
Old Jun 5, 2006 | 02:09 PM
tmeracz's Avatar
The bushings are only different between the cast and stamped LCA's themselves.
For obvious design reasons...
Old Jun 5, 2006 | 04:06 PM
ED9man's Avatar
I mean the trailing arm bushing. Isn't there a big or small one depending on the trailing arm? Also is the trailing arm exactly the same as 90-91 CRX trailing arms? No alignment change? Also what is the deal with the e-brake cables? Do they even make them anymore?
Old Jun 5, 2006 | 04:26 PM
mahatma's Avatar
I believe you're right, Integra's bushings were slightly bigger.
Old Jun 5, 2006 | 08:11 PM
tmeracz's Avatar
Default Re: (mahatma)
Well this got me curious. My friend & I changed trailing arm bushings on both of our cars but ordered CRX/Civic replacement parts from E.S.
The E.S. catalog shows the same part # for 88-00 Civics and 94-01 Integra's: 16.7106.
90-93 Integra's are a different part #: 16.7107
This would support the argument that the trailing arm bushings are different in diameter.
You're gonna need to find out exactly what year of Integra trailing arm you have.
Old Jun 6, 2006 | 03:26 AM
ED9man's Avatar
Thanks. Does anyone know about the e-brake cables? Aren't there like 3 seperate parts? Do I need all three?
Also the stock 90-91 CRX Si prop valve is 2040?
Modified by ED9man at 7:58 AM 6/6/2006
Old Jun 6, 2006 | 06:21 AM
temp's Avatar
http://www.fourthgenhatch.net/reardiscswap.html
/thread
Old Jun 6, 2006 | 07:27 AM
Tyson's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ED9man &raquo;</TD></TR><TR><TD CLASS="quote">
yes
Old Jun 6, 2006 | 07:39 AM
temp's Avatar
Default Re: (temp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by temp &raquo;</TD></TR><TR><TD CLASS="quote">http://www.fourthgenhatch.net/reardiscswap.html
/thread</TD></TR></TABLE>
Old Jun 6, 2006 | 05:10 PM
ED9man's Avatar
I've looked at that, I'm just wondering what part of the cables I need, especially since I am planning on pulling Integra TA's and they won't have them.
http://www.hondaautomotivepart...BRAKE
In that picture which parts? I noticed the main brake line seems to be discontinued? Could I be wrong?
Old Jun 6, 2006 | 05:31 PM
temp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ED9man &raquo;</TD></TR><TR><TD CLASS="quote">I've looked at that, I'm just wondering what part of the cables I need, especially since I am planning on pulling Integra TA's and they won't have them.
In that picture which parts? I noticed the main brake line seems to be discontinued? Could I be wrong?</TD></TR></TABLE>
he says exactly what you need in that link.
Old Jun 6, 2006 | 05:44 PM
ED9man's Avatar
No he doesn't, I want to know which cables I need. In that diagram I see three cables.
Old Jun 6, 2006 | 05:51 PM
tmeracz's Avatar
CRX e-brake cables from a CRX with disc brakes in rear are what you will need.
In the diagram I believe it's part #12, that's it.
I gave up looking for new parts too around the time I did the swap.
You can get the part from a junkyard. I lucked out and found trailing arms that were complete.
I've never trashed my ebrake cables so bad that they've failed, even used ones.
If they're off a wreck, they might be soiled with dirt, just shoot some penetrating oil into the sheath and work the cable until it moves easily. Then install.
Old Jun 6, 2006 | 06:05 PM
temp's Avatar
Default Re: (tmeracz)
why in the expletive do i have to show everyone how to ******* read
"90-93 Integra Rear Trailing Arms (with everything attached Rotor, Caliper, Ebrake Cables...)
or
90-91 CRX Rear Trailing Arms (with same...) "
DIRECT QUOTE FROM THE FIRST LINES OF TEXT ON THE LINK I PROVIDED
******* hell i should just take a gun to my head, i cant take lazy asshats anymore.
Old Jun 6, 2006 | 07:05 PM
Tyson's Avatar
Default Re: (temp)
bad day huh.
step away from the keyboard, son.
Old Jun 6, 2006 | 07:06 PM
temp's Avatar
Default Re: (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">bad day huh.
step away from the keyboard, son.</TD></TR></TABLE>
lol, thanks tyson. that made me laugh .
Old Jun 7, 2006 | 05:06 PM
ED9man's Avatar
Thanks, that answered my question. I'm guessing the two shorter ones are in the TA's?
I saw that part on the website, the plural cables could mean the two shorter ones or all 3, so it didn't answer my question. Get it?
Old Jun 7, 2006 | 05:07 PM
temp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ED9man &raquo;</TD></TR><TR><TD CLASS="quote">Thanks, that answered my question. I'm guessing the two shorter ones are in the TA's?
I saw that part on the website, the plural cables could mean the two shorter ones or all 3, so it didn't answer my question. Get it? </TD></TR></TABLE>
no, but apparently you dont use this thing called logic and/or common sense.
jacksonww
Oct 5, 2010 05:09 AM
wickedEFguy
Jun 23, 2009 03:07 PM
serb_rida
Suspension & Brakes
Jun 19, 2008 04:16 PM
Fishcat37
11
Apr 9, 2003 11:16 PM
shortyz
Oct 18, 2002 10:32 AM
