Quick question about the ASR brace kit
Old May 31, 2006 | 10:04 AM
bsixteen's Avatar
Default Quick question about the ASR brace kit
Gotta quick question before i buy the kit w/ the 22mm sway bar. is there anything in the kit that i would need that i wouldn't get by buying JUST the ASR brace w/o the sway bar and getting the sway bar from http://www.barancoacuraparts.c...t.jsp
the ASR kit w/o the bar is 180 and the bar + endlinks from baranco is 118.29=298.29+shipping for the ASR kit
vs the 340 from ASR...so..is there anything w/ the ASR kit that i would be missing that i need?
i know the saving may be minuscule but i need to save where i can
Old May 31, 2006 | 10:41 AM
SuperSlow's Avatar
Default Re: Quick question about the ASR brace kit (bsixteen)
you need the d brackets for 22mm.
Old May 31, 2006 | 10:49 AM
bsixteen's Avatar
Default Re: Quick question about the ASR brace kit (SuperSlow)
would you happen to know how much the D brackets cost?
Old May 31, 2006 | 11:23 AM
allmotorpowa's Avatar
dude you cant just buy a sway bar.. you gotta buy all the little **** like the D brackets and ****. just look at the honda site and get everything you need in the picture which is probly everything
Old May 31, 2006 | 11:51 AM
Voyage34's Avatar
Default Re: (allmotorpowa)
I got my d-brackets and bushings from Summit for something like $15.
IIRC for the ITR bar you would also need to use your stock Si endlinks as the integra ones wont line up quite right
Old May 31, 2006 | 12:09 PM
pdiggitydogg's Avatar
your local parts store probably sells 7/8" D bushings also, which IS 22mm
Old May 31, 2006 | 12:52 PM
Relic1's Avatar
Default Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">your local parts store probably sells 7/8" D bushings also, which IS 22mm</TD></TR></TABLE>
best place to get them
the end links are the harder part to get...
Old May 31, 2006 | 03:35 PM
BlueIntegraBoy's Avatar
If you get just the ASR kit, you will need...
52300-ST7-Z01 SWAY BAR (QTY: 1)
52315-ST7-Z01 SWAY BAR BUSHING (QTY: 2)
52308-SS0-000 SWAY BAR BRACKET (QTY: 2)
52321-S04-003 END LINK LEFT (QTY: 1)
52320-S04-003 END LINK RIGHT (QTY: 1)
90002-S10-000 NUT, FLANGE (10MM) (QTY: 2)
90212-SA5-003 NUT, SELF-LOCK (10MM) (QTY: 2)
Old May 31, 2006 | 05:15 PM
bsixteen's Avatar
doesn't come up on the acura site..are those the oem SI end links? seems like it would be almost the same as just getting the kit lol oh well its good to know
Old May 31, 2006 | 06:12 PM
Default Re: (bsixteen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bsixteen &raquo;</TD></TR><TR><TD CLASS="quote">52321-S04-003 END LINK LEFT (QTY: 1)
doesn't come up on the acura site..are those the oem SI end links? seems like it would be almost the same as just getting the kit lol oh well its good to know </TD></TR></TABLE>
These are Si endlinks
Old Jun 1, 2006 | 05:42 AM
bsixteen's Avatar
blah i don't know if all this sourcing is worth the hassle of $40 lol guess its time to save!
BlackShingo
Suspension & Brakes
May 14, 2010 05:33 PM
odogg726
Feb 21, 2007 09:22 PM
zeroz
May 9, 2005 12:12 AM
Kev95lx
Sep 26, 2003 05:54 AM
