code 6
Old May 31, 2006 | 09:30 AM
court's Avatar
25 Year Member
Default code 6
I have a code 6 ECT. that is thhe single plug on the side of the head correct?
currently the plug is harnessed in and does not look faulty. It is the only code I have, and my car is running a little ruff from it. Anyone had symptoms like this
Old May 31, 2006 | 09:48 AM
crx_88_si's Avatar
the engine has a total of 3 coolant related sensors.
1. on the back of the block for the rad fans (just a simple thermoswitch, not hooked to ecu)
2. under the dist sensor for the guage cluster, again, not connected to ecu
3. under the dist beside #2, this is the ecu temp sensor.
here ya go.
Old Jun 3, 2006 | 01:20 PM
court's Avatar
25 Year Member
Default Re: (crx_88_si)
yo, thanks for the info mang, but check this out....
so stock on the motor, the ect switch is in the back by the thermostat
I put another one from the old motor on the head( where it is on the d15b2)
when i connect the plug in the back of the block, the cell switch works
when i connect it to the one on the head it doesnt blink, it just stays (check engine)
any ideas? bad ecu maybe?
Old Jun 6, 2006 | 06:07 PM
court's Avatar
25 Year Member
Default Re: (court)
I found my reading at the ecu to be 5v correct. I found my reading at the plug to be 4.9 v
would thisd be enough variance to make it throw a code ? .1v?
Old Jun 6, 2006 | 08:09 PM
court's Avatar
25 Year Member
Default Re: (court)
ok, so I belive I cleared the code. the dash doesnt read a check light, but if I jump the cel, I still get 6 flashes; code 6
Old Jun 8, 2006 | 02:06 PM
court's Avatar
25 Year Member
Default Re: (court)
bueler
liljohn850
15
Jul 9, 2011 12:19 PM
rudyndrew
Dec 30, 2010 02:12 PM
SPOOLINmatt
Mar 17, 2010 05:43 PM
waciii
Oct 26, 2008 06:57 PM
